I will refit the rear crank seal
08.05.2020 16:23 # 1
arslanbey01
I had my friends put the rear crank seal on my vehicle 2 times, but I could not prevent oil leakage, the master said that he came from the crank seal again. He said he missed the rear crank seal when I took him to the checkup for 307 mi. There is a leak at the point where the gearbox and engine meet. It is not the gearbox oil that is the engine oil. Since the gearbox and engine are at the junction, the service said that the rear is cranked. I bought the felt from the service. but my question is, is there any other wicket to be fitted with 1-crank seal or just goat because my master just wears the seal? There is no dry oil leak, it does not come from the top cover gasket.)
3-while the rear crank seal is changing, some people should apply liquid gaskets. My master did not do anything like this. He says that if I force it, the crankshaft will miss it. Is this possible? Maybe it is due to me. When I put this felt on the master as well, it still leaks If it is used in this way, it will be a problem because the infiltration has been leaking for 2 weeks. If the infiltration continues, would it be a problem for me to use it
Thank you very much if you answer. & nbsp;
