I will get 407
08.05.2020 21:18 # 1
fatihz
Hello, I will buy a 407 tomorrow, we will specialize the vehicle, the vehicle 2007 model 407 1.6 HDI manual, 250 thousand km, what do you suggest to pay particular attention to when buying the vehicle? Thank you in advance for your help.
08.05.2020 21:18 # 2
whisky
Instead of a fixed flywheel, there is a spring-loaded flywheel on the vehicle and the pressure pad is usually replaced with the pad. and cheap is not a piece either. In other words, if heavy maintenance has come, this set of vehicles will only cost you 2.5 parts. look at the history of heavy maintenance. I would also check if the signal headlight arm was working smoothly. can cause chronic trouble. I strongly recommend you to check your air conditioner because after a certain year the air conditioner compressor is weakening in such vehicles (which is a costly thing: D) and I recommend you to have it checked separately as it does not provide enough pressure. These are the things that come to my mind.
08.05.2020 21:18 # 3
fatihz
Is there any way to figure out if the flywheel has changed or not?
08.05.2020 21:18 # 4
whisky
As I said, teacher, we change the press brake pads at once to avoid paying labor twice. If it is time for heavy maintenance of your vehicle, you can change it and rest your head in one go. The printing varies with the pad, so whenever you change it, you will add it to the account.
