I will buy a vehicle
08.05.2020 20:30 # 1
mchtaknc
Hello,
I found a vehicle, the owner has 206 roland garros, but the model is 8v. Apart from that, the vehicle's 279 thousand vehicles are out of sight. I scratch a little because of km but will it cause problems?
mchtaknc 2017-08-10 12:41:34
08.05.2020 20:30 # 2
Honestly, my car has actually been worn down according to the age of km. If you don't know when the vehicle is probably installed, you may have trouble with the engine. price is not good why does the air conditioner work? front gear - axles - press brake, engine power, etc. whether the engine burns oil etc. you need to take a good look.
08.05.2020 20:30 # 3
mchtaknc
Exactly, I want to have a look at them to discuss them. I am amazed how many years old the damage record pattern is already. There is a bit of anxiety just because of the engine, it is no problem for me to be painted inside. Let's say I bought it, do you have any problems when selling it?
08.05.2020 20:30 # 4
my teacher has a buyer for every vehicle. how much cost you have to take care of it, you have to think like how many km you do in a year
08.05.2020 20:30 # 5
x571
[QUOTE = mchtaknc] Hello,
Add an average maintenance cost of 6 thousand pounds. Since our country does not have a regular care culture, you should definitely have it under good care. Nevertheless, before buying, you need to look at the front of the engine or something.
08.05.2020 20:30 # 6
talip206
Do not forget that nobody sells good goods at cheap prices. If it wants 16 to the vehicle with a market of 20 21, it means that the vehicle has many troubles.
If you think I will get no expenses, do not approach. But if I say I buy cheap 3 I will pay 5 thousand.
Generally what needs to be checked and estimated costs.
If there is a shortage of torsion, around 800 1000 TL.
If the pressure is close to the pad, it is around 500 TL.
The timing of the timing change is around 400 to 500.
If the front team is very troubled, it is around 500 600.
If the signal arm is troubled, the com2000 cost is around 300 500.
If the tires are bad, around 500.
Depending on the engine performance, there may be costs from 1000 to 3000 pounds.
You can look at their general condition and make an assessment in your mind.
talip206 2017-08-10 22:11:35
08.05.2020 20:30 # 7
lazerburak
I think buying a vehicle that is under the market will surely cost you a little bit, so I would say to raise the number a little more and see a more reasonable vehicle.
