I will buy a new car |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 308 (2008-2013) | |
| 08.05.2020 21:06 | # 1 |
I have two questions for you. I would be glad if you share your valuable comments with me. Question 1: 308 Diesel is automatic or manual, whichever is more successful ? Question 2: Do they have chronic problems? Thank you in advance...
| 08.05.2020 21:06 | # 2 |
sonerkyl |
First of all, welcome to us. I hope you will find a vehicle according to your heart. 1- The automatic ones have the auto6r semi-automatic 6-speed single-clutch transmission. You will feel gears when passing 1-2, because there is no problem in the next gears, because it is a single clutch, but after you get used to it, you will not have a problem. Many of my friends use 308 semi automatic diesel and they are satisfied. Fuel consumption is lower than manual vehicles, of course, depending on the region conditions you will use. The difference between manual and automatic is that your manual maintenance costs are low. The only problem we can call 2-chronic is that the suspension system is a bit stiff and we can say trim sounds on rough roads. 3-I was close to 2 years 308 1.6 vti gasoline car, I am glad I bought it, I traveled about 40000 km in Berlin, I did not have a problem other than standard maintenance.
| 08.05.2020 21:06 | # 3 |
[QUOTE = EDI34] Hi 308 I'm thinking of buying a diesel. It will probably be from 2009 to 2011. I have two questions for you. I would be glad if you share your valuable comments with me. Question 1: 308 Diesel is automatic or manual, whichever is more successful ? Question 2: Do they have chronic problems? Thank you in advance... [/ QUOTE] Hello there, 1- I think it is automatic. both are good 2- I did not use it for a long time, I used it for 9 months, but I did not see the chronic problem. The only bristle was that there was an excessive engine noise coming from the forefoot, before the room disappeared every 308, wander well after that.
