I will add LPG to 307, what should I do
08.05.2020 17:23 # 1
thejackal44
Friends 2002 model 307 1.6 I am thinking of getting lpg on my vehicle, what do you suggest, atiker say no installation. What kind of problems do I have after installing LPG, thank you
08.05.2020 17:23 # 2
Serkan
If you find a good master, half of the forum has an affiliate, the brand will remain in the second plan. Master first
08.05.2020 17:23 # 3
elsoberano
If your master is good and scarce good, you will not have a problem.
08.05.2020 17:23 # 4
thejackal44
Do you know who has an atiker from Eskişehir or a good master from Eskişehir
08.05.2020 17:23 # 5
thejackal44
08.05.2020 17:23 # 6
thejackal44
No big husband from Eskişehir
08.05.2020 17:23 # 7
silivriserdar
BRC appreciation I searched for a while, they say fine. I use a wiper, but when I bought it there was already a weapon.
08.05.2020 17:23 # 8
impact
I am very glad I have landirenzo. I do not know if there is atieker in our other car there is zavoli. After 4500-5000 cycles, injectors could not catch up and switched to gasoline.
08.05.2020 17:23 # 9
offchu
Pejo vehicles are very good about Lpg teacher, I suggest you do good research and we would be better helped if you stated a budget in your message. If you say I will pay for money, I recommend prins teleflex style kits BRC for middle class, I recommend landirenzo lovato is also good, but the master is more important than all these brands. I got prins, I am very happy about the fuel, but when the engine is cold, the car trembles and when I want to take off, it does not eat gas (when it is in gas), it shifts when it passes to the gas.
08.05.2020 17:23 # 10
impact
[QUOTE = offchu] Pejo vehicles are very good about Lpg teacher, I suggest you do good research and we would have been better helped if you had stated a budget in your message. If you say I will pay for money, I recommend prins teleflex style kits BRC for middle class, I recommend landirenzo lovato is also good, but the master is more important than all these brands. I got prins, I am very happy about the fuel, but when the engine is cold, the car vibrates and when I want to take off, it does not eat gas (when it is in gasoline), it shifts when it passes to the gas. > your trouble is in the gas pump or hoses .. vectrada we had the same problem we changed the pump continued the same problem there was a hose there was a crushing twist at the outlet of the pump there was a problem when it replaced the hose ..
08.05.2020 17:23 # 11
enes_468
I have researched a lot like you and I have 206 people who say "atiker takt" and they go and pour money to foreign brands. safafest brand kit. 4 & nbsp; I had 900 TL for a month ago and 1100 TL. I heard a lot, no malfunction lamp lights, no car, no gas, etc etc etc my brain was dirty. If the master wears the malfunction, the goods are mine, he said, I'll throw it away, he will encourage me. It has not been a mistake for 4 months, and super fuel now burns 290 cents in the city. What more can you get? & Nbsp; & nbsp;
08.05.2020 17:23 # 12
eray307
Earlier, those who called peugeota tube fitting were plugged, and 2 years ago, we had a 900tlye tube installed in Eskişehir atiker, and I saw those who said it was right. I had problems like the engine lamp was on, the spark plugs were harvested. I do not know if the solenoid valves have changed in the last 1 month ago. it is ridiculous to have to throw gasoline, I think
08.05.2020 17:23 # 13
thejackal44
last month, I had an atiker, as most friends say, I made it to the best called master, let's see earlier, but for now there is no problem, I hope not, respect
08.05.2020 17:23 # 14
altugg34
How much did it cost? Have you installed the psa module? Is the malfunction lamp on? Generally satisfied, what is your fuel consumption?
08.05.2020 17:23 # 15
fexzi
Instead of the 1000 TL AKL brand fitted spare wheel, the performance of the number 10 in the triptonic vehicle, I burn 23 krş is in ... Research and fit the compatibility of the harmony rather than the brand condition. gas is released until the circuit, it does not transfer to gasoline.
08.05.2020 17:23 # 16
thejackal44
I had it installed for 990 TL, there is no problem for now, as everyone said, rather than the important brand from the master, yes, the malfunction lamp is on, the malfunction lamp is always on, it was always on when it took fuel outside of where you bought gasoline. My engine master said he did not take it to the lamp, he said it will be on everything because it is very sensitive, we put it in the computer, it did not find a fault, it went out again, but it is on fire now but do not mind as I said
08.05.2020 17:23 # 17
ismailkaya
& nbsp; skilled craftsman need & nbsp; atiker obd (obidi mi ne) 1100 tl 30-40 & nbsp; tl. Between the sealing attachment form 1-2-3 will be filled anyway 160 TL. licenses will change 150-170 rubles. gasoline 4.56 tl & nbsp; gas 2.50 tl & nbsp; gasoline average 7-8 lt of room at 100km 4.56 * 7 = 36.48
gas 100 km. average & nbsp; 10 lt burns room 2.50 * 10 = 25 tl & nbsp; & nbsp; & nbsp; bg = difference & nbsp; 36,48-25 = 11,48 tl at this 15,000 km lpg pays for yourself & nbsp; then you go to kera
08.05.2020 17:23 # 18
ersin025
I had a mind called super obd2 system, I said what is different from normal mind, he said he uses the same brain as lovato, and this system takes all the information from the brain of the vehicle and integrates himself & nbsp; He said, I appreciate it. I have no problem for now. I did not have a breakdown lamp. I tested the inter-city mixed. 20 lit. lit. I am both surprised and I am very happy. and don't forget to have it installed in the lubrication system.
08.05.2020 17:23 # 19
dream
I have a 2006 model 307 xt Premium BVA automatic vehicle, but I cannot make a decision about LPG.
If I get it? If I don't get it?
(I don't travel a little too)
08.05.2020 17:23 # 20
ersin025
my car 2005 307 xs 1.6 16 valve I have had it installed, I have traveled about 1200 km since thankfully I am very pleased I did not realize it before installing it, now I realized that gasoline really hurt me. :)
Page : / 2
