I was on the road for 307 sw car sacmaladi help lü
08.05.2020 20:44 # 1
Furkan979
First of all, good days, while going to our relatives, the car gave yellow exclamation mark at first, then gave "electricy circuits fault" after the car stopped and started the problem went away 4 or 5 km later, the car stop signal burned and gave all kinds of errors on the screen hand brake abs airbag and roll It fell to 0, then it went out on the radio screen, now I came home from obd I read it high voltage says I will run it one more time, now it is not working, it turned back to 2003, mars donuyo beep sounds, the car does not work, says auto revidi please help, I'm afraid, thank you in advance
08.05.2020 20:44 # 2
OguzhanKucuk61
Try to remove the battery terminal, wait 5 minutes and plug it in. Maybe it will help.
08.05.2020 20:44 # 3
ismailkaya
Actually, the vehicle tells you the fault well. He says high voltage, he talks about automatic revision. What did you do to this vehicle electrically? it seems to me a very simple malfunction. Get well soon
08.05.2020 20:44 # 4
Furkan979
I was scared when I saw all the malfunctions on the screen, but I am glad that it came to my house, I hope it is a simple problem as you say thank you for your answer
08.05.2020 20:44 # 5
Furkan979
[QUOTE = OguzhanKucuk61] Try to disconnect the battery terminal and wait for 5 minutes. Maybe it will help. [/ QUOTE]
I will try before going to the service tomorrow thank you
08.05.2020 20:44 # 6
talip206
Probably the dynamo started to produce excess current. The Buddha burned all the faults. The zeroing of the history and the return of the language to French occurred because there was no current from the battery for a certain period of time. The broken current may have damaged the battery.
08.05.2020 20:44 # 7
Furkan979
[QUOTE = talip206] Probably the dynamo started generating excess current. The Buddha burned all the faults. The zeroing of the history and the return of the language to French occurred because there was no current from the battery for a certain period of time. The broken current may have damaged the battery. [/ QUOTE]
I have a charger for the charger, so I gave this error, but I do not know exactly, I go to the service for 3 or 3 hours.
08.05.2020 20:44 # 8
No, as our furkan archery says, your problem arising from the charging dynamo. I hope there was no problem with the battery.
08.05.2020 20:44 # 9
ggitaristt
The first thing that comes to my mind is the charge controller regulator failure. Because high voltage has no other possibility ..
08.05.2020 20:44 # 10
Furkan979
[QUOTE = ggitaristt] The first charge dynamo regulator malfunction that comes to my mind .. Because high voltage has no other possibility ..
As you said, I made the charger dynamo burned so he said. There is no problem for now. Thank God.
08.05.2020 20:44 # 11
pusutr
Get well soon.
08.05.2020 20:44 # 12
ggitaristt
Get well soon .. I can predict the fear that he has experienced Big smile
08.05.2020 20:44 # 13
Furkan979
Thank you very much, we've all been on the road with a car for the first time.
