I was on an emergency road
08.05.2020 18:54 # 1
RuhAdam3466
My 306 gasoline and my auto car remained on the road, I put the fuel, but it doesn't work. What should I do ...
08.05.2020 18:54 # 2
RuhAdam3466
If friends have urgent information, my sharing is about to end in my charge
08.05.2020 18:54 # 3
Alicilik
If you are on the road with auto, call your relatives and if the battery is dead, you should connect and start it with another vehicle.
08.05.2020 18:54 # 4
RuhAdam3466
Gasoline is over, we added, it has nothing to do with the battery
08.05.2020 18:54 # 5
RuhAdam3466
Friends I stayed on the top of the mountain. If you do not know about this topic ....
Let me summarize the event as follows; When I was about to run out of gas, I thought I would take the ramp off, I continued on the road, saying that the car stopped after the ramp came out ... I pulled over the side of the road, because it is a secluded place, no one comes to pass, it doesn't help in the past. I filled 5 lt gasoline in the trunk, it still doesn't work. Because the car is automatic, it is not a question of knocking!
Note: When Always Starting The Car, Its Ignition Is Out Of The 3rd Stage, It Sounds Sounds, It Does Not Now Is It Caused By This Or Is It Possible To Have Air?
08.05.2020 18:54 # 6
baybaba
Is trunk traveled with 5 liters of gas? isn't it dangerous? Is there a gas station shortage, and if you have gasoline
why did you wait for the fuel to run out completely?
08.05.2020 18:54 # 7
samet206
Hodja, don't let the gas pump burn, you cut the gas.
08.05.2020 18:54 # 8
RuhAdam3466
I used to use 5 liter of gasoline in difficult times.
08.05.2020 18:54 # 9
RuhAdam3466
[QUOTE = baybaba] Can you visit the trunk with 5 liters of gasoline? isn't it dangerous? If there is a gas station shortage, and if you have gasoline, why did you expect & nbsp;
fuel to run out completely? & nbsp; & nbsp;
It used to be a voice in his contagion at the second level.
08.05.2020 18:54 # 10
ismailkaya
I may be stuck, I wonder if it stops, why not try to stop the contact and stop the battery leaves
08.05.2020 18:54 # 11
RuhAdam3466
[QUOTE = ismailkaya] I wonder if I get stuck, why should I stop working while standing still stops pressing the contact to stop the battery [/ QUOTE]
How Do I Know It
08.05.2020 18:54 # 12
zerzevat
Call 155.
08.05.2020 18:54 # 13
samet206
By the way, but what is the situation last?
08.05.2020 18:54 # 14
ibanez_022
If the petrol pump pulled from the bottom of the tank and overheated, either the fuse was blown or burned, you may not find the insurance at night, if you know the location, try to get a fuse from somewhere else.
08.05.2020 18:54 # 15
ibanez_022
could you write the last situation?
