I was on a very urgent road
08.05.2020 17:54 # 1
hexen
My friends car 2004 307 xs automatic vehicle does not come out of the park, there is no latch on the brake pedal, I stopped, I restarted, I locked it, I did not act back, I got the engine of the car, I trusted it, I was able to wash it out in a place I didn't know, I couldn't solve it.
08.05.2020 17:54 # 2
Mehmet38
The brake pedal must be brown on the brake pedal. Short-circuit and try to exit the parking mode.
08.05.2020 17:54 # 3
error
Does it happen immediately after washing?
08.05.2020 17:54 # 4
hexen
I'll look right at that brown musure
No, I used it for 10 and 15 minutes, it was okay to get out of the washing machine.
08.05.2020 17:54 # 5
hexen
In order to make a short circuit, it is necessary to change it to the poles with a screwdriver.
08.05.2020 17:54 # 6
error
Remove the socket on the brake switch and insert a paper clip into that socket.
and then you can measure the sender to an electrician and I hope only the sender is broken
08.05.2020 17:54 # 7
hexen
I pulled out the socket and put it back on, the latch opened for a moment, but this time the car was at the same time, even though it was at the same time, I was stopped in the park for a while, but if I took it back to the park, it was in the park again. I got out of the park but do not be afraid I did not break it because it locked it again when I took it to the park again, I got another slap opened again.
08.05.2020 17:54 # 8
error
no violence LOL
joking aside, it seems like the side effects of engine washing.
08.05.2020 17:54 # 9
Alicilik
I hope water has not got into the brain. Like an electronic thing.
08.05.2020 17:54 # 10
samet206
I was thinking about washing the engine for the past, I hope I got it right now, I hope the problem is not caused by washing.
08.05.2020 17:54 # 11
Alicilik
[QUOTE = samet206] I was thinking of washing the engine for the past, I got it right now I hope it is not the problem.
I wash the cars of our house and relatives by myself. I wash the engine every 3-4 months.
08.05.2020 17:54 # 12
volkan22
Since I bought my car, I haven't even clothed the engine :)) What does water mean?
08.05.2020 17:54 # 13
Bunyamin.Kar
I want to wash or wash the inside of the engine, but after reading these events, I say let it be dirty :)
08.05.2020 17:54 # 14
qqyyxx
If the engine is washed as if it was washing the outside of the car, there may be a problem. If you do not skip the points that need attention, there is no problem
08.05.2020 17:54 # 15
hexen
I was a little late, but I think the problem was caused by the breakdown of the gearbox contactor, the water has escaped into it, thanks to the failure of the gearbox, but the contactor was found to be intact, and it was put in calibration and the problem disappeared. But keep in mind that this piece is under the battery, it is not a place that is washed in the back of the cable, as other friends have said, it is not a place where you wash it.
