I was just burning the car :(
08.05.2020 19:54 # 1
red 206
My friends were throwing white smoke on the way to the friends, the master said normal. Later, when the vehicle hit the mountain ramp, the car smelled from the right side, the glass smelled right from the right, I pulled the windows to the right without waiting for it. of course we melted the room oil cubes and a few sensor connection cables inexpensive. What do you think the reason why the katalixator warms up and freezes to the elev ball? The master catalyst said that the room that had gone from the turbo oil was included in it, why do you think that I could not have even gotten 3,000 by putting the turbo from the engine of a 50,000 km vehicle and why did you think it was caused? Where should I make the turbo, repair is good. Thanks in advance.
Accident-free days
08.05.2020 19:54 # 2
I wish that the past has been preserved by Allah. The turbo will most likely request revision, as you said. a good turbocharger must be found and made. I think the cost should be around 400-500 per room.
08.05.2020 19:54 # 3
red 206
It was hollow, I think it would have burned before if it was already full. Bakicaz does not run out of this car.: (((
08.05.2020 19:54 # 4
I understood then, as the master said, it looks like it originates from the turbo.
08.05.2020 19:54 # 5
OguzhanKucuk61
Get well soon
08.05.2020 19:54 # 6
red 206
Thanks.
08.05.2020 19:54 # 7
akundakci
Get well, bless Allah
08.05.2020 19:54 # 8
red 206
Amen master first mine sentence then mine mine.
08.05.2020 19:54 # 9
Gokcesel
Get well soon, my teacher, you are saved. I just need to carry a fire tube in the vehicle just in case now I understood its importance once more.
08.05.2020 19:54 # 10
red 206
Definitely my master, so if you were not a servant of a god where I stood, you would be on the highway or in another place, the car was burned :( thank you for sure. sheep.
08.05.2020 19:54 # 11
Gokcesel
[QUOTE = red 206] Definitely my master, so if I was not a servant of a god, I was on the highway or in another place, the car was burned. If you can put it, put a suitable tube of medium size. [/ QUOTE]
Even if it doesn't happen on our own, it can happen to someone else. It is okay to take a small footprint in the trunk. Get past once more
08.05.2020 19:54 # 12
ersin61
Get well, my friend ...
08.05.2020 19:54 # 13
red 206
Eywallah my master saoalsin
08.05.2020 19:54 # 14
Cyrus35
God bless the wicked of the past, after reading my brother, I will immediately take a fire extinguisher tube and put it in the trunk Unhappy
In the meantime, the diagnosis of the master is correct, I think the oil that the turbo sends to the floor is evaporated due to the reason of the smoke.
08.05.2020 19:54 # 15
red 206
Just as my master came and passed, now we are trying to collect the heat shield turbo air filter and so on. they couldn't get it off because they realized it; and they could barely lock their doors when they were in the car, but they couldn't get the car locked, but the second one was the problem that the car burned into the catalyst of the car, and if the first burning part was the heat shield, the peugeot would make the shield from the heat, if it was made of meta-material from the metal shield ...
08.05.2020 19:54 # 16
Cyrus35
The spongy material actually does not burn, my professor of fiber is much more beneficial than the damage of the fiber. It is just like the gasoline that is poured into the ground and put on fire. The degree of manifold outlet can reach very high figures. Nothing could prevent the oil in the hot pipe from catching fire there, but I wondered why the flame was not in the floor or exhausted by pressure.
08.05.2020 19:54 # 17
red 206
There was no tear in the manifold, the heat shield inside the catalyst is getting hot, the heat shield starts to see the heat shield, which you call the fiber. Then the paper burns when the temperature in the burning degree reaches. Here is the same situation here. Again, it is a bad situation that may be ridiculous for me.
08.05.2020 19:54 # 18
Cyrus35
Of course, one cannot evaluate this possible situation better without thinking that better measures could be taken.
08.05.2020 19:54 # 19
aslanaft
get past bro a fire is a medium size fire extinguisher is a must we give and receive our cars 100 lira if the tube is a lot maybe there is not that much
08.05.2020 19:54 # 20
red 206
It is not more than 100 tl. You have your hands checked once a year. Even if it is yearly, we have already spent 10 times.
