I want ybili from 206 users please
08.05.2020 18:11 # 1
donjuan1920
friends did not operate the handbrake in the 206s but the exclamation mark is on but the exclamation mark is on when the
turns on the ignition & nbsp; the exclamation mark is always on when the lights are on, but the hand brake is not pulled out & nbsp; sevinirm
08.05.2020 18:11 # 2
Turgay_66
Turn all the lights on, turn on the ignition, sir, I couldn't fully understand the problem?
08.05.2020 18:11 # 3
Aziz
There is a brake sender, it may have started to trouble.
(Note: fix it if I'm wrong)
08.05.2020 18:11 # 4
donjuan1920
the car is not working, the hand brake is not pulled, but the hand brake sill light is on, the car is running
08.05.2020 18:11 # 5
Turgay_66
[QUOTE = donjuan1920] the car is not working, the hand brake is not pulled, but the hand brake sill light is on, the car is running off [/ QUOTE] Is it lit without inserting a key?
08.05.2020 18:11 # 6
donjuan1920
No key is attached, I turn the key and turn on the lights, I do not start the hand brake lamp is on, I turn the handbrake on and off, but it does not go off then I start the car everything is working
08.05.2020 18:11 # 7
Turgay_66
What do you mean, my teacher, Estağfirullah. if your vehicle is like this no problem :) Turgay_66 2014-01-07 17:59:51
08.05.2020 18:11 # 8
Turgay_66
[QUOTE = Turgay_66] What does it mean, my teacher, astaghfirullah. they go out when the vehicle starts, if your vehicle is like this, no problem:) [/ QUOTE]
08.05.2020 18:11 # 9
donjuan1920
As you said, they are all lit up, but the brake light is on until the car starts, the brake is on with the battery, the brake is on, and it does not stop when I lower the brake.
08.05.2020 18:11 # 10
Turgay_66
[QUOTE = donjuan1920], as you said, all is on, but the brake light is on until the vehicle is running, the battery is on, the brake is on, the brake does not stop when I lower the brake & nbsp; [/ QUOTE] My teacher presses that button when you lower the brake, the lever presses that button and the lamp It goes out normally, but there may be a problem with the part I said in the vehicle, if you can find the place I said, I recommend you to try it by pressing it with your hand. Turgay_66 2014-01-07 18:05:45
08.05.2020 18:11 # 11
donjuan1920
But here is a problem, there is no problem while the car is running, I put the handbrake down and it goes out
08.05.2020 18:11 # 12
Turgay_66
[QUOTE = donjuan1920] but there is a problem like this, there is no problem while the car is running, I have to put down the handbrake, it shuts down when it shuts down & nbsp; Turgay_66 2014-01-07 18:10:10
08.05.2020 18:11 # 13
donjuan1920
Thank you very much for your interest and concern.
08.05.2020 18:11 # 14
Turgay_66
[QUOTE = donjuan1920] thank you very much for your interest and interest. [/ QUOTE]
You're welcome :)
08.05.2020 18:11 # 15
kursat3006
No problem normal
08.05.2020 18:11 # 16
muhammed.ceyhan
Whether the parking brake is lowered or raised, the parking brake light is on when the ignition is on, and all the lights are on. If you start the car, all the lights go out. if you have released the parking brake. If you have not lowered all lights except the parking brake light.
NOTE: this is the case for all vehicles. Reviews
