I want urgent help
19.04.2021 21:13 # 1
berate38
Good evening to everyone, I have 1.4 gasoline 90hp trendy package 207, my vehicle is leaking oil from the corner of the engine block from the corner of the spark plug at 135 thousand km. I wanted to change the timing maintenance of the vehicle. They confused me that the block was completely aluminum and after putting the gasket, it was cracking while torque while giving degrees, it was getting blocks at 75 percent. I would be glad if there are new generation pejo in Kayseri, but I trust 135 thousand. berate38 2021-04-19 21:14:18
19.04.2021 23:12 # 2
207power
Hello,
I don't think anything will happen as the masters say. I know the industry of Kayseri more or less, there are not many skilled masters. In my opinion, do not take any risks and change the gasket at the authorized service ... It will be the address of any problem.
20.04.2021 00:09 # 3
berate38
They want exactly 2 times the workmanship. Do you have information on whether I can buy and take parts from the outside, or do I have to use the parts there?
21.04.2021 21:32 # 4
207power
[QUOTE = berate38] They want exactly 2 times the workmanship. Do you know if I can buy and take parts from outside, do you know the ace or do I have to use the parts? [/ QUOTE]
They do not accept external parts. You use the part that is available in authorized service. The important thing here is not the part but the workmanship, because you can buy the original part elsewhere and have it made in industry.
207power 2021-04-21 21:35:13
23.04.2021 23:28 # 5
berate38
I received a workmanship fee of around 2 thousand TL from the authorized service. As you know, the parts prices are a little higher at the service, it is around 4500 TL. Currently, there is no environment to give this money nor I have a situation in the industry, but I do not have confidence, I do not know that I need to reassure the car once it is dismantled. I don't know if it keeps order or not, I even started to think about selling it. If I have knowledgeable brothers and sisters, I need your mind.
