|   | I want to print my car, but? |
| 08.05.2020 17:38 | # 1 |
|  howard | |
| 08.05.2020 17:38 | # 2 |
|  Guests | |
I want to print too, but the roads are bad. But I just apply the gas to the brake  | |
| 08.05.2020 17:38 | # 3 |
|  howard | |
| the soup sucks, but the road works continue at full speed :) I mean there is a 4cm gap I mean, if I press this vehicle back to me as minus comfort and pat bump sound :) or what kind of suspension can be suggested my goal is to go and bow not to take a nap anyway | |
| 08.05.2020 17:38 | # 4 |
|  Gokhan Cetin | |
can be air suspension  | |
| 08.05.2020 17:38 | # 5 |
|  Guests | |
Master never mind, if you are going to use Çorlu only in the market, the roads are generally rough. I do not think of stepping the car in life. I go to the village at the top of the mountain with 206 and there are frictions even in its original form. Bassam emits. & Nbsp; I think the rims are enough. This is my personal opinion. & Nbsp;
| 08.05.2020 17:38 | # 6 |
|  howard | |
| You are right so a suspension that can rise whenever you want will work, the suggestion of your friend is that the air suspension idea is nice, but the cost goes up to 8 thousand TL. | |
| 08.05.2020 17:38 | # 7 |
|  Guests | |
[QUOTE = howard]  you are right so a suspension that can rise whenever you want will work as well, the suggestion of your friend is the idea of air suspension is nice, but the cost of up to 8 thousand rubles is satin stone crack. [/ QUOTE] Coilover is air suspension? if so how 8bin ya?     http://www.sahibinden.com/search.php?b%5Bsearch_text%5D=coilover+peugeot+206   | |
| 08.05.2020 17:38 | # 8 |
|  howard | |
not the coilover, its the best, with the 3 thousand lira assembly, the air suspension I say is not on the trailers of these trucks, the blower, this is the shock absorber, you put the tube in the back, it sounds like a bit for the air, but the air makes it sound like a bellows bus :) how reliable .. the moment you blow that blower will not be clear where you will fly
| 08.05.2020 17:38 | # 9 |
|  Guests | |
| [QUOTE = howard] coilover is not the best, with the 3 thousand lira assembly, the air suspension I say is not in the trailer of these trucks, the bellows buddha is a shock absorber bellows, you put a tube in the back, it sounds like a bit for the air but it makes a sound like a bellows bus separately. There are those who do 2-3 thousand or so, but how reliable it is .. the moment you blow it, it will not be clear where the blower will fly because [/ QUOTE]  eheyyyyy & nbsp;  | |
