I want to make a 307 led dial, let's help
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 14:58 # 1
formulaone
friends I want to turn all of my 307 indicators into a led indicator, waiting for friends to help or where can we get them
Uploaded with ImageShack.us
08.05.2020 14:58 # 2
Haksen016
If you want to consult the reform tuning above, you can also find out if there is a sample of it.
08.05.2020 14:58 # 3
individual
you have led
I think you meant I want to change the color
08.05.2020 14:58 # 4
Haksen016
As far as I understand, he wanted to illuminate it like the pictures above.
08.05.2020 14:58 # 5
we need to be awesome emrah 2010-11-21 16:20:15
08.05.2020 14:58 # 6
ali oncu
I guess he put those pictures as an example, but good practice
08.05.2020 14:58 # 7
307P
It looks super, I want to do it too.
08.05.2020 14:58 # 8
individual
there are various applications here.
Maybe it gives an idea
http://www.forum307.com/viewtopic.php?t=32758
08.05.2020 14:58 # 9
Haksen016
Very nice work takes care of people, but it must be very difficult to get it done here.
08.05.2020 14:58 # 10
individual
We had a friend doing this work in Istanbul from another forum.
I think it's white, for example
08.05.2020 14:58 # 11
[QUOTE = individual]
Can you let me know when you have a brother
08.05.2020 14:58 # 12
ceronimo1978
Greetings to all, I am dealing with indicators as a result of my job. It is a very risky business to remove the indicator after disassembling, you can damage the electronic circuit. In addition, while the indicator is being collected again, the hands need to be driven in the correct position, otherwise you may be mistaken in speed, fuel and heat, there may be a chance of the needle rubbing against the dial, which either draws your adran or breaks the stepper motor, you also need to consider them. Also, when the white leds are applied instead of the existing leds are yellow, it will be necessary to find and install the appropriate resistance. If this match is ignored, you burn the card, which means the indicator goes to the trash. As I said, I would say do not do it very risky without research. Although I work in a factory producing indicators, I do not dare believe it.
08.05.2020 14:58 # 13
formulaone
I applied the pictures to my car, the LED dial is the finished state of the work.
08.05.2020 14:58 # 14
BurcUMUL
looks just fine. health to your hand
08.05.2020 14:58 # 15
ceronimo1978
my teacher looks amazing. Did you use white led and resistor in the indicator in your application, and white bulb in the trip computer and heater control?
08.05.2020 14:58 # 16
m.peker
I wonder where you made it so beautiful
08.05.2020 14:58 # 17
individual
If I am not mistaken on the 307 indicator, there are 8 leds.
3 speeds, 3 speeds, 1 gasoline and 1 temperature
08.05.2020 14:58 # 18
juventa
I wonder where and how much you made my teacher.
08.05.2020 14:58 # 19
Haksen016
I think I got those images from another site.
08.05.2020 14:58 # 20
Haksen016
The individual nickname in the forum, the expert on this subject, had very good work on his car.
Page : / 2
