I Want to Install PSA Module on My 307 Vehicle
08.05.2020 17:27 # 1
Naclore
Hello.
My car 307 XT Tiptronic BRC Lpg is available. You know that there is a place in Antalya that wears this tool because I cannot understand how many times I have been on the road because of it.
08.05.2020 17:27 # 2
impact
I think you should have my car gas pump broken out of gasoline has been lying in front of the door for 1 week ..
08.05.2020 17:27 # 3
Naclore
Yes, it causes a lot of problems. In some places, the vehicle shows down the gasoline in the tank. It is not downhill. How many times have I paralyzed the traffic & nbsp; "Approve"
08.05.2020 17:27 # 4
Serkan
You need to burn every place that assembles lpg, you can take the module from the net and have it installed in a service.
08.05.2020 17:27 # 5
Naclore
OK thanks. But this module should be compatible with the model of lpg.
08.05.2020 17:27 # 6
Serkan
No, my teacher is not compatible with the brand, they connect to the cables coming out of the tank, and when the contact is closed, the float resets the float when the vehicle is in motion. There is a method, the details are in the link
http://forum.peugeotturkey.com/forum_posts.asp?TID=13780&title=lpg-de-benzin-ibresi-dmesi- problem-cheap-zM Reviews
08.05.2020 17:27 # 7
msk_sansal
it was as if someone managed to prevent the gasoline needle from falling without the PSA being installed.
08.05.2020 17:27 # 8
Serkan
Right on your message :)
08.05.2020 17:27 # 9
msk_sansal
anaaa sorry teacher i got out of work new head trillion: D
08.05.2020 17:27 # 10
Naclore
How, even if I put it on, will it fall on the road? So how did you manage, or is there any other method?
08.05.2020 17:27 # 11
Serkan
Let me explain, hojam, for example, you filled the gas tank of the vehicle and the LPG tank, you have set off, you have traveled 400 km without stopping with LPG, meanwhile, your gas gauge will drop, but when you stop and start the car, the gas gauge will show real gas again.
08.05.2020 17:27 # 12
Naclore
Ok I got it. Thanks Serco05. By the way, is there a reliable site that sells this module and I don't want it to be cheap?
