I want to get information about 306.
08.05.2020 20:26 # 1
AhmetSehzade
Hello Friends, Easy Come
I Want To Buy 306 But Which Would You Recommend?
gti thought it burns so of course
I was thinking about the 1.6 platinium I read something about going in a few places.
Which category would you recommend in the 1.8 category?
Which and how many models do you think? in ahmetsehza 2017-06-22 17:36:30
08.05.2020 20:26 # 2
AhmetSehzade
Nobody Can Help?
08.05.2020 20:26 # 3
If you are going to buy my brother Ahmet, I recommend you to look at the ones with high model. I recommend 1.6 platinum, it is hard to find themes under 20 thousand rubles under the latest 306 models as well as the themes that are close to 2000 models. There is an abs airbag as equipment.
08.05.2020 20:26 # 4
AhmetSehzade
[QUOTE = sonerkyl] If you are going to buy my brother Ahmet, I would suggest you to look at the ones with high model. I recommend 1.6 platinum, it is hard to find themes under 20 thousand rubles under the latest 306 models as well as the themes that are close to 2000 models. There is an abs airbag as equipment.
Thanks for your beautiful comment
I Will Have Another Question 1.6 How Will The Pull Go?
4 People Thousands of Air Conditioning Affected When I Open It I guess I heard it.
08.05.2020 20:26 # 5
You're welcome. Indeed, Ahmet Kerdeşim, the same problem occurs in most gasoline vehicles running under 2.0 engine. The course of the vehicle depends on many factors, depending on the press brake - engine condition - fuel - maintenance etc. My advice is to look at the vehicles you like, I recommend you to turn to any one or two laps. Because the performance expectancy depends on the person, I use it, I say it is good super departure. you use, you don't like
08.05.2020 20:26 # 6
AhmetSehzade
[QUOTE = sonerkyl] You're welcome. Indeed, Ahmet Kerdeşim, the same problem occurs in most gasoline vehicles running under 2.0 engine. The course of the vehicle depends on many factors, depending on the press brake - engine condition - fuel - maintenance etc. My advice is to look at the vehicles you like, I recommend you to turn to any one or two laps. Because the performance expectancy depends on the person, I use it, I say it is good super departure. you use it, you don't like it [/ QUOTE]
Thank you so much
08.05.2020 20:26 # 7
outlaw
I have 106 xs 1,6 izmir atatürk mah who knows that he knows he has very steep slopes, air conditioner is turned on 3 people come out like a monster, this is about motor health ...
1.6 2.0 does not matter ... outlaw 2017-06-23 11:20:06
08.05.2020 20:26 # 8
x571
[QUOTE = AhmetSehzade] [QUOTE = sonerkyl] Thank you. Indeed, Ahmet Kerdeşim, the same problem occurs in most gasoline vehicles running under 2.0 engine. The course of the vehicle depends on many factors, depending on the press brake - engine condition - fuel - maintenance etc. My advice is to look at the vehicles you like, I recommend you to turn to any one or two laps. Because the performance expectancy depends on the person, I use it, I say it is good super departure. you use it, you don't like it [/ QUOTE]
Thank you so much
I am using 2002 306 1.6. There is nothing I can say badly about traction.
Their themes are sold in the range of 22 - 25. I recommend you to get it clean because it comes with the same money, but go to the industry and get bored. If you have any other questions, my answers are good holidays.
08.05.2020 20:26 # 9
AhmetSehzade
[QUOTE = x571] [QUOTE = AhmetSehzade] [QUOTE = sonerkyl] Thank you. Indeed, Ahmet Kerdeşim, the same problem occurs in most gasoline vehicles running under 2.0 engine. The course of the vehicle depends on many factors, depending on the press brake - engine condition - fuel - maintenance etc. My advice is to look at the vehicles you like, I recommend you to turn to any one or two laps. Because the performance expectancy depends on the person, I use it, I say it is good super departure. you use it, you don't like it [/ QUOTE]
Thank you so much
They do not say good things for Peugeot. I should listen. They say buy Opel Corsa. Peugeot is a little sensitive car. How do you think as a user?
08.05.2020 20:26 # 10
Karacocuk24
Badly maintained maintenance is not done on time, all the important parts of the cable that were pulled from the cable cause problems that have not changed with the original 17 "wheel followers.
08.05.2020 20:26 # 11
x571
[QUOTE = AhmetSehzade] [QUOTE = x571] [QUOTE = AhmetSehzade] [QUOTE = sonerkyl] Thank you. Indeed, Ahmet Kerdeşim, the same problem occurs in most gasoline vehicles running under 2.0 engine. The course of the vehicle depends on many factors, depending on the press brake - engine condition - fuel - maintenance etc. My advice is to look at the vehicles you like, I recommend you to turn to any one or two laps. Because the performance expectancy depends on the person, I use it, I say it is good super departure. you use it, you don't like it [/ QUOTE]
Thank you so much
They do not say good things for Peugeot, I should hang on. They say buy Opel Corsa Peugeot is a little sensitive car. How do you think as a user? [/ QUOTE]
What are they saying, for example. Because we always use bugatti as a nation, we don't like other tools. I think it has performance compared to its price. When I bought it, I just paid attention to it being clean. I bought something with low maintenance. I recommend to you too. If you buy a maintenance-free vehicle, you will pay the cost that the man did not do before you. There are chronic problems in some models. In the light of the abs, I am having a breakdown before the light bulb of km meter burst.
08.05.2020 20:26 # 12
AhmetSehzade
[QUOTE = x571] [QUOTE = AhmetSehzade] [QUOTE = x571] [QUOTE = AhmetSehzade] [QUOTE = sonerkyl] Thank you. Indeed, Ahmet Kerdeşim, the same problem occurs in most gasoline vehicles running under 2.0 engine. The course of the vehicle depends on many factors, depending on the press brake - engine condition - fuel - maintenance etc. My advice is to look at the vehicles you like, I recommend you to turn to any one or two laps. Because the performance expectancy depends on the person, I use it, I say it is good super departure. you use it, you don't like it [/ QUOTE]
Thank you so much
What's the difference between 1.6 platnum and xr? Friends
And That Is A Question Stuck In My Head.
08.05.2020 20:26 # 13
AhmetSehzade
What is the difference between platinum and xr? you know what?
