I want to change the speaker
08.05.2020 17:19 # 1
rakasan
Friends, I want to ask you a few things, I have 206, and the speakers are not healthy, when the car turns right and left, there is a noise cut and it makes a bad noise.
08.05.2020 17:19 # 2
serkan719
depending on the speaker brand & nbsp;
depends on you & nbsp;
60 lira sony & nbsp; - jameson 35 lira & nbsp;
around 100 material when you get the front back like
would + craftsmanship
08.05.2020 17:19 # 3
ekinoks44
I think the front speaker is bursting, I think I'm changing. Which brand do you recommend in terms of price and performance?
08.05.2020 17:19 # 4
Serkan
The front is 16 cm, the back is 13 cm, but I don't know about performance
08.05.2020 17:19 # 5
ufuk91
it is neither very good nor pioneer that will upset you, they are not very, very expensive, but when you see cheap speakers on the market, they can be expensive. I bought 2 13'l 70tl in the back, I put it myself
08.05.2020 17:19 # 6
KenBlockJR
Get the highest rms of the 3 way ones. sony-jbl-pioneer-hertz-alpine is good.
piranha-navitech-jvc is of lower quality.
08.05.2020 17:19 # 7
barutcu17
speaker size 307 and 206 all twill
08.05.2020 17:19 # 8
Serkan
[QUOTE = koliva]
I think there is all the information you are looking for. So they are 16.5 cm, the back is 13 cm. The tweeters in them are 4.8 cm.
By the way, it is important at maximum depth. Maximum depth dimensions of 53mm for tweeters, 85mm for ten speakers and 80mm for rear.
08.05.2020 17:19 # 9
front 16 cm back 13 cm coaxial speaker.
08.05.2020 17:19 # 10
gngburak
[QUOTE = rakasan] Guys, I want to ask you a few things, I have 206, and the speakers are not healthy, when the car turns right and left, the sound is cut off and it makes noise, I want to change the speaker but I want to change how much the total cost and labor cost and what brand should I buy. Would you recommend? & nbsp; [/ QUOTE]
If it comes from your hand, you can simply disassemble it yourself.
& nbsp;
I had the same problem 1 pair pioner 17cm I bought a 200 watt speaker, I bought it, I bought it 54tl.
& nbsp;
08.05.2020 17:19 # 11
rakasan
[QUOTE = gngburak] [QUOTE = rakasan] Friends I want to ask you a few things, I have 206 and the speakers are not healthy, when the car turns right and left, there is a noise cut and it makes a noise, I want to change the speaker but how much is the total cost with labor You can keep it, and what brand would you recommend me to buy? There were also 1 pair pioner 17cm 200wat speaker I bought 54TL I bought it myself. I'm familiar, I only have problems with the rear speakers, do you suggest pioners?
08.05.2020 17:19 # 12
rakasan
eyw thank you :)
08.05.2020 17:19 # 13
herry
Well, let me ask you, I am not happy with my rear speakers, but I have a bass amp and bass in my car, so it does not support the rear speaker. Are you still saying ppiooner as a speaker that my confirmation can feed?
08.05.2020 17:19 # 14
herry
For example, I found two models in the 13cm pioner, one of them says 130 wt 40 TL for one way, and the other says double wired mid and treble.
08.05.2020 17:19 # 15
rakasan
I haven't gotten it yet, but the sound coming from day to day makes me crazy :) My passion for listening to music has escaped & nbsp;
08.05.2020 17:19 # 16
Bursat
I was going to replace the rear speakers, but after removing a screw, I couldn't remove the side. I did not want to force in not to break if there are nails etc. Now I came to investigate how to disassemble video. & Nbsp;
Editing: I found related titles as a note. & nbsp;
Video 207 but the logic is the same
[TUBE] s1eGMOL2ooA [/ TUBE]
Bursat 2013-03-05 16:36:33
08.05.2020 17:19 # 17
Bursat
I removed the door, but all & nbsp; clips & nbsp; were broken. I also realized that it has nothing to do with slowing down. Because the clip entry system of the 307s in my model is mixed. It should be enough to pull the console up after removing the screw, but you cannot do it because the clip inlets are different. One consists of the right, one to the left, one up and one down.
The summary of the work is troublesome but the assembly part is enjoyable ^^
08.05.2020 17:19 # 18
ekinoks44
I changed the loudspeaker in the front today. An affordable product & nbsp; I chose to take it. (Goldmaster 4-Way 500W 30TL) The process of removing the door was a bit difficult. >
