I want to buy a Peugeot 307
08.05.2020 20:46 # 1
Bilalkosk
First of all, hello my friends, I am new in the form of friends, I think to buy pejo 307, I am a sunroof, but it is not important, I live in Antalya, I work in a private hospital. I like it very much, I would appreciate it if you help me with full self regards Bilalkosk 2018-02-16 15:10:00
08.05.2020 20:46 # 2
Bilalkosk
I forgot to write friends, I'm looking for gasoline and manual
08.05.2020 20:46 # 3
keqir
I think 21 thousand is a very small number, if you are not going to buy anything, you should be at least 25-26.
08.05.2020 20:46 # 4
talip206
[QUOTE = keqir] I think 21 thousand is a very small number, if you are not going to buy anything, you should go up to 25-26th [/ QUOTE]
I agree. 307 you get at that price may hurt your head.
08.05.2020 20:46 # 5
Bilalkosk
https://www.sahibinden.com/ilan/vasita-otomobil-peugeot-memurdan-temiz-525774041/detay
The damage record says that there are 600 defects and the man is clean and there is no problem.
08.05.2020 20:46 # 6
Orcun.Dmr
I would definitely recommend it for 7 years. But I wouldn't recommend buying 307 at those prices.
08.05.2020 20:46 # 7
HasGur
[QUOTE = Bilalkosk] https://www.sahibinden.com/ilan/vasita-otomobil-peugeot-memurdan-temiz-525774041/detay
The damage record says that there are as many as 600 flaws, no clean shortage, if you don't get anything out of the control check, do you think [/ QUOTE]
Without mentioning the vehicle in the link you provided; 3 years ago, it was revealed that the 2008 focus, which was called "Immaculate, examiner, has no problem ... Painted because of sunburn, no damage record", changed the ceiling and right front door. I don't know what the situation is there, but never mind the computests ... If you have a body / paint and engine master you trust, decide after you show them to buy the vehicle you are interested in. If you do not have an environment in the industry, you can ask and find one of the well-known spare parts in the industry that sell the parts of the brand vehicle you will buy, they will direct you to a few of the masters that can be trusted.
08.05.2020 20:46 # 8
maximusti
They usually get on the tractor as if they are getting on the tractor.
you need to have it checked well. and definitely record the damage according to the chassis number ..
08.05.2020 20:46 # 9
x571
that car is not taken.
08.05.2020 20:46 # 10
ismailkaya
If you say the vehicle is not a single problem, 21,000 TL. A car you can find but you will have to sell it at the same prices while you sell it. You will cost 7000 TL from wherever you look, because the engine water circulation hoses of the vehicles between 2004 and BEFORE 2005-2006-2007 are now in the engine, engine torsion bushings, rear torsion bushes, amasor tocosis. and ball tires, charger, catalyst sensors and catalyst engine oil treatments, timing and clutch assembly spark plugs, linings and discs as the model year that is time to change.
08.05.2020 20:46 # 11
ggitaristt
[QUOTE = ismailkaya] If you say the vehicle is not a single problem, 21,000 TL. A car you can find but you will have to sell it at the same prices while you sell it. You will cost 7000 TL from wherever you look, because the engine water circulation hoses of the vehicles between 2004 and BEFORE 2005-2006-2007 are now in the engine, engine torsion bushings, rear torsion bushes, amasor tocosis. and ball tires, charger, catalyst sensors, and catalyst engine oil treatments, timing and clutch assembly spark plugs, pads and discs as the model year from which it is time to replace [/ QUOTE]
This friend is right, my car has changed to 2006 diesel and counted and more.
I would not recommend purchasing 20000 tlye such old and equipped vehicles.
08.05.2020 20:46 # 12
emrah_860
I do not recommend this car because the car is single-door, and it can be a bit troublesome to sell black, and the vehicle decision is 217 km.
08.05.2020 20:46 # 13
ben_erhan
Did you buy a car, my friend?
If you haven't bought it, check the condition of crnoic problems such as air conditioner, signal lever, warning screen, cd player etc.
08.05.2020 20:46 # 14
subasi88
friends good evening, i am thinking of getting a 307 model make up case with a comfort package. the automatic gear lpg is installed about ten thousand km ago, now at 113 thousand. I know that make-up safes are problematic, is this also true for make-up safes, or have their relative problems been resolved? Is solenoid valve shortage also present? If you are using a make-up case, I am waiting for your comments.
