I want to apply window film to my 307 vehicle |
| 08.05.2020 20:32 | # 1 |
| 08.05.2020 20:32 | # 2 |
sonerkyl |
I think my brother needs to disassemble after you have the necessary materials. but it is a bit more laborious in french vehicles like peugeot. It is due to glass wicks. It is not important to break the clips. 50 krş is sold from spare parts but if you say I expect a very cheap link on aliexpreste and if you have this type of apparatus, it's better will do much in this video. [TUBE] agxwmcdxwcm [/ TUBE] |
| 08.05.2020 20:32 | # 3 |
KILIC |
For the first time I saw why mirrors are not electric in 307 in this video :)
| 08.05.2020 20:32 | # 4 |
[QUOTE = KILIÇ] Why the mirrors are not electric for the first time in 307 in this video:) [/ QUOTE] Unfortunately our xr (empty) safes are here. In my car, the front is electric, the rear and mirrors are manual. But I turn it into 4 glass automatic
I bought 4 glass and mirror automatic installations and will apply after the feast. ![]() |
| 08.05.2020 20:32 | # 5 |
I watched while I was filming my teacher 308, only manual skills and experience were required. The man made 5 glasses for about 45 minutes. There is no need for you to disassemble and install a place. You only need film apparatus. You take the measurement from the outside and then cut it on the inside and fix it with the brush and take air with the apparatus. There is nothing else. They say use glasses for 2 days so that they do not slip. |
| 08.05.2020 20:32 | # 6 |
Door trims can also be made without disassembling, but I guess that there will be no lift after you do it on time. But it will be very comfortable when the door upholstery is removed. If you say why it is better not to shoot in front of me, I shot number 3 movies including windshields, the view goes to zero in rainy weather and you do not have the opportunity to open the window. first unscrew the glass button (if I remember correctly, the screws were removed with T20), and then there will be 3 more screws in the upholstery.
| 08.05.2020 20:32 | # 7 |
Thanks for your valuable comments I bought my materials today, I started to disassemble it from the driver's door, I tried to not break the clips as much as possible. I bought the spray paint in the worn spray paint on the plastic part with the glass automat while I was removing it, I hope I can sand it with fine sandpaper and paint it there.
| 08.05.2020 20:32 | # 8 |
I recommend you get it done by people.
| 08.05.2020 20:32 | # 9 |
[QUOTE = cr1me] Thank you for your valuable comments I bought my materials today, I started to disassemble it from the driver's door, I tried to not break the clips as much as possible. I bought the spray paint in the worn spray paint on the plastic part with the glass automat while I was removing it, I hope I can sand it with fine sandpaper and paint it there. After removing the tors screws located around the door trim, you need to pull it upwards by pulling it slowly from the bottom.
