I want my front team ??
08.05.2020 16:37 # 1
eserxxx
Hello friends, I have the 2003 model, 307 2.0 HDI & nbsp;. I searched in the forum but I did not encounter a similar problem, if any, it was overlooked, do not look at my fault. For the last 2 months, when the vehicle has moved after the first run during the day, there is a clicking sound, there is the same clicking sound in the 1st and 2nd gears when I pull my foot off the gas. When the engine warms up, there is no sound and it does not sound again during the day. Until the first departure the next day. I think it comes from wheels but I couldn't figure it out. Another sound is a squeak that I thought was coming from the left front wheel as the car rocked on the road. This sound comes when you turn the steering wheel, even on the straight path. At first the weather was cold, I said it from him, but the voice started to increase gradually. I open and listen to the window, the sound is loud, the same as the sound from the old American vehicles. I wonder if anyone happened to you, what is the solution ??
08.05.2020 16:37 # 2
albayman
If there is a condition that stiffness, ossification or an extraordinary situation in gear changes, there may be a transmission wedge. If the engine is running jerky, there may be engine ears / wedges. possibly a clutch / flywheel maybe. If the squeal is happening on the road, or it is punching the wheel like this, a bolt might be loosened. the previous vehicle had a creak, they did not find it was 3 months nervous, they did not find the place I had not looked at. The master & nbsp; noticed by chance while checking the lpg maintenance. There was no creaking when he tightened the screws. There is a possibility that the shock absorber may be squeaking. When the front team lifts and controls the master fiber, he already tells the parts to change.
08.05.2020 16:37 # 3
eserxxx
There is no peculiarity in the vehicle, no matter whether it is going, acceleration, engine sound or vibration. There's only those squeaks :(
08.05.2020 16:37 # 4
dukenukem82
those squeaks come from the towers on the front team, but I think there is no need.
08.05.2020 16:37 # 5
gabriel
Hello, I think a similar situation to my friend's problem exists in my vehicle. my car peugeot 206 hdi 1.4 diesel..the last 10 days or so ... for example, after starting the car, the gas pedal is pressed lightly as if two iron is rubbed together, how do I say it. I wonder what could be the reason. Can you think of Triger or something ...
08.05.2020 16:37 # 6
fiveiron
My friend started to tell you the situation in your vehicle too. I try to tell you, too.
08.05.2020 16:37 # 7
The clicker comes from the crosshead bushings, especially in cold weather, it becomes more evident with the hard tire. Don't worry, the sound does not go. The shock absorber etc. needs to be replaced with the bushings.
08.05.2020 16:37 # 8
phoenix.1905
Sounds may be coming from swings.
08.05.2020 16:37 # 9
fiveiron
friends, I figured out the squeaking sound.It was from the accessory belt.First I started the car, then I sprayed the oil with a fist on the belt. The sound was cut off. the master said he was giving turbon oil. i went to a turbocharger. he said nothing. he took out the turbo hose and showed his propeller. he said no gap.
08.05.2020 16:37 # 10
fiveiron
I forgot to write the question.
08.05.2020 16:37 # 11
Bartender42
Why do you want to disassemble the turbo, my friend? Removable Of course why not disassemble ... I think there is no need for the scheme, when you remove the aluminum coated felt on the front part, the screws are visible clearly, you can solve this problem with the ALYAN Team with a long solid construction that will work for you ...
