I want information about the antenna
08.05.2020 19:47 # 1
Karacocuk24
Hello friends my car 2001 model automatic 206 xr I have a few questions I changed the original cassette tape, but the radios do not pull well, the vehicle pulls normally while stopping, but it rustles on the way according to my research on the internet. Would you help the antenna circuit electronics or a standard antenna?
08.05.2020 19:47 # 2
vpro
The tape you just installed should take precautions if it is new in production. If you have such a problem, there may be a booster or something.
08.05.2020 19:47 # 3
GokhaN
I had it installed in 106, there was no problem with the original antenna. I did not use anything other than the original antenna.
08.05.2020 19:47 # 4
samet206
I had a different brand of tape in my car, I used it with the original antenna, sometimes I was having trouble pulling it. Then I bought a higher quality tape, and this time I installed it myself, the thing I saw was cut off the tip from the original antenna of the vehicle and replaced with a new tip. it does not fit the antenna output, I opened it myself and made a cleaner attachment, and then I did not have the problem of not pulling it. As a summary, it was a problem due to the attachment, or I did not think it would be a problem to use a different tape with the original antenna.
08.05.2020 19:47 # 5
Sercan Mungan
There is a kenwood brand tape in my vehicle, it was mounted on the original ends of the vehicle without mowing. However, the wearer said that he had connected it to the ignition but after he got out of the car and locked the doors, after 2 or 3 minutes his own closing, the door starts to play again.
08.05.2020 19:47 # 6
Gokcesel
[QUOTE = Sercan Mungan] There is a kenwood brand tape in my car, it was mounted on the original ends of the vehicle without mowing. Is it connected? [/ QUOTE]
If it is not connected to the contact, it is also closed when the contact is closed. There is no wrong connection, it was like yours when I first installed it. It was closing after 1 minute. When I removed the contact, the tape was opened when the doors were opened. I do not want the evening dress wearing the tape as I do not want it to be so, I said I want it to be connected to the contact and adjusted it accordingly.
If you are dissatisfied, come back to the person you had the tape, and I would like the tape to turn off when I remove the key.
08.05.2020 19:47 # 7
samet206
That type of connection is something like a feature of the tape, that is, when a different connection opens the door with the key from the outside, it opens the tape with that trigger, there are such things, but if it is connected to the contact, the tape does not open.
08.05.2020 19:47 # 8
Sercan Mungan
It's been 1.5 years, I can't even take a place Smile we will handle it at the forum meeting LOL
08.05.2020 19:47 # 9
Karacocuk24
I have not used any transducer at the end of the original antenna, but I used a commercially available transducer, but as you say, it feels like it feels like going on the road, it may be related to the quality of the tape.
08.05.2020 19:47 # 10
vpro
[QUOTE = Karacocuk24] I did not do any operation at the end of the original antenna, but I used the converter sold in the market, but it may be related to the quality of the tape, as you said, it may be related to the quality of the tape on some roads.
An interesting solution is not resistance. Radion cannot stand though. D.: D
