I waited for 2 days making the air
08.05.2020 16:39 # 1
sarp
When I stopped my 2006 partner 1.9 in front of the house, I do not run one day, I have to open the hood and pump it. There is oxygen or water in the diesel when the landing is low when the speed is low. this is getting air from all over the place, but we even lifted it up with the lift, but we couldn't see a leak in a humidification.
08.05.2020 16:39 # 2
dynamic07
I think it is useful to replace the diesel filter.
08.05.2020 16:39 # 3
sarp
all maintenance has been done 2 months but the problem persists. All filters have been changed. Generally, 10,000 maintenance is on the 2nd day.
08.05.2020 16:39 # 4
There are two possibilities:
1. The pipes with low pressure, from the fuel tank to the pump, have very little legs and the pump draws air. Member 2. There is a leak in the injection pump.
If I was at your place, I would start with option 2 first.
08.05.2020 16:39 # 5
Ali
I don't know if there is a diesel automatic but there may be an automatic problem.
08.05.2020 16:39 # 6
sarp
The injection pump may be before the sender who says there is water or oxygen in the diesel because I do not understand that my vehicle is signaling at low speed at high speed for 1-2 minutes and there is no water left. I checked every screw that I could keep in mind, it does it again. I think of the client's seal that I call but I do not dare to disassemble. there is no particle pattern & nbsp; I say I don't ride, diesel is very expensive, but when I run it, I'm going to do what I do.
