I WAIT FOR YOUR AIDS ABOUT THE SHOCK ABSORBER ...
08.05.2020 13:59 # 1
iLLeGaL
friends, I have a problem about this shock absorber, when my car is passing through the XR and especially the cobblestone streets or a small pit bump-like obstacle, it is the place where I say that I feel the stone is too hard or there is no cure, but I would be glad if you share your opinion. ..
08.05.2020 13:59 # 2
Have you checked the shock absorbers? or does the sound come from all of them regularly?
08.05.2020 13:59 # 3
iLLeGaL
The chassis of the vehicle is playing completely, it is cluttered, but there is no sound on the flat road.
08.05.2020 13:59 # 4
sam106
If the amortisors are hardened or hardened, will it shake?
08.05.2020 13:59 # 5
iLLeGaL
best of all, let's take a look at the shock absorber, if we need it, we will change it now ...
08.05.2020 13:59 # 6
Suspension system consists of Shock Absorber, Coil Spring, Swing and Carrier
Is there any modification or modification in one or more of these, if standard, how many thousand km of the vehicle (they may have filled their shoulder)
08.05.2020 13:59 # 7
It may have broken the top link. It is generally found in the rear augers.
08.05.2020 13:59 # 8
The vehicle is 106 mertcim, there is no spiral at the back, there is a torsion bar
08.05.2020 13:59 # 9
ayyy =) then it may have been ahead Deran brother ne daughterosn 106 do not use kiyyyy
08.05.2020 13:59 # 10
EMRE
I have the same problem, 206 tools are 5 cm down, but hissterethiom brackets were not in the foreground. I hope the problem started to shake these days. I hope there is no big problem.
08.05.2020 13:59 # 11
aoc
1- Voices informing us that our car is Peugeot,
2- Troubled sounds ..
Let me make a different claim, steering wheel;)
08.05.2020 13:59 # 12
GokhaN
I think try to degrade the tires
If there is a sound coming from right to left, you will not care much.
08.05.2020 13:59 # 13
iLLeGaL
[QUOTE = DERAN_TUYNER] Suspension system consists of Shock Absorber, Coil Spring, Swing and Carrier
There is no mode in the car, as a front set, spring, etc. my car, 98 model 112000, I know someone said that the shock absorber balls may have been scattered, but I do not know I have to show it to the master ...
08.05.2020 13:59 # 14
[QUOTE = aoc] 1- Voices informing us that our car is Peugeot,
Yes bro, I agree with you, a problem we forgot,
it is likely to be from the steering wheel.
08.05.2020 13:59 # 15
m.peker
Actually, it looks like the magical problems in peutos. I have 307. The rear shock absorbers make sound when passing through the sets and pits.
mtfpk is 2010-11-10 23:00:08
08.05.2020 13:59 # 16
One of the biggest problems of peugeot is making a sound.
08.05.2020 13:59 # 17
If we approach the gull-loving mast with its folding logic, the suspension is very good in the grip, but if it is the softest road, it makes a sound, but if it is soft it is comfortable on rough roads but the road grip is weak.
In addition, this hardness and sound condition are valid for all 307 and c4s that have the same suspension. For example, if we compare the old versions of 307 and c4 to 307, the old versions are less soft and less comfortable. but they never make amortizing sound. For some reason, the new series comes from the rear suspension very often and the torsion structure in the old case is absent in the new ones. I have heard from many masters, you can not find the comfort of old ones. this is really true. but the safety in the new ones is more ... only this situation may be relevant in the context of the depreciation problem used. need to research ...
the cecol 2010-11-11 09:42:04
