I use power to steal my 307 xt horn |
| 08.05.2020 18:28 | # 1 |
| 08.05.2020 18:28 | # 2 |
The repair of this is so simple ... Under the airbag, the horn has a chassis cable, then it oxidizes, it holds 1 screw, it is enough to remove the screw, clean and replace it with the tip of a screwdriver.
| 08.05.2020 18:28 | # 3 |
Bugra |
If you say I can't do it yourself, auto electricians will take care of it.
| 08.05.2020 18:28 | # 4 |
My vehicle doesn't steal at all. The steering wheel was said to open up the flour and was difficult to collect. I haven't done it yet. There is no problem in the electrical parts. it may be oxidized in me. but watch out when opening.
| 08.05.2020 18:28 | # 5 |
tolga.onal |
It is necessary to use some power when opening the forum, there is a photo narration, it should be noted that while removing the middle part of the steering wheel, do not damage the airbag locks or you can open costly problems.
| 08.05.2020 18:28 | # 6 |
tolga.onal |
here i found it .... http://www.peugeotturkey.com/nasil_yapilir.asp?makaleıd=65
| 08.05.2020 18:28 | # 7 |
thanks guys but i cant go somewhere and look
| 08.05.2020 18:28 | # 8 |
65serdal58 |
Go to the electrician. It does not take 5 minutes ... I had the same problem with me.
| 08.05.2020 18:28 | # 9 |
how many TL
| 08.05.2020 18:28 | # 10 |
65serdal58 |
morning order 10 liras |
