I Think of Buying 307 1.6 90 HP |
| 08.05.2020 18:55 | # 1 |
| 08.05.2020 18:55 | # 2 |
By the way, I forgot to write the car 2007 model |
| 08.05.2020 18:55 | # 3 |
What is the price of the vehicle
| 08.05.2020 18:55 | # 4 |
[QUOTE = colonel] I did not use 206 diesel. but the following can be done. WHEN TESTING THE VEHICLE: 1.) Torque band (1.4 hdi I think it gives max torque from 2000 revolutions). 2.) Meanwhile, if an external friend is an observer, is the exhaust smoke too black? 3.) if there is a trip computer, straight road 5th gear will go at a constant speed of 90km, while instant consumption will not show more than 3-4 liters (it can even go under 3 liters) WHEN OPENING AND LOOKING UNDER THE HOOD 4.) When the engine is idling, when the bonnet is picked up, remove the injector camouflage cover and listen to the injectors one by one. 5.) Give small gases from time to time to see if there is lubrication or smoke in the bottom of the injector. 6.) Listen to the turbo in the same way. Have excessive hissing or whistling. Does it sound like twitches or similar? if there is a chance to look under the engine 7.) Is there any lubrication etc.? These come to my mind. more experienced friends please take my gap ... [/ QUOTE] see my comment to friend who will buy diesel above. I'm glad I have 307 sw. I can keep the average of 5 liters of fuel in these winter days. hatchback will be lighter, more serial performance. burns less (depending on usage), if possible, make an exporter. beautiful tool, do not be battered, you will regret it very much. |
| 08.05.2020 18:55 | # 5 |
He wrote 28.000 but we will negotiate. Of course, I found 110 in 128 thousand in one of them. They said that the maintenance of everything was done in these two vehicles. I can not decide the 2006 model, which is 110.000 TL 26.000. I mean I know I couldn't decide ..
| 08.05.2020 18:55 | # 6 |
I bought 307sw 1.6hdi 90 comfort vehicle 25.500e in August. It was 90 thousand kilometers. I don't know if hatchback is 26-28. depends on the cleanliness of the vehicle. If the performance is at the forefront, I recommend 110. but in performance use, the fuel increases a lot. I do not think there will be anything other than the year difference between 2006 and 2007, they are both make-up cases. amaaa, if the low mileage is a clean 110 premium, there are ways up to 30 thousand TL ... |
| 08.05.2020 18:55 | # 7 |
I hope I will go to look at a 307 1.6 90 hp 82 thousand tomorrow. I did not understand that they put the car that I bought 28.000 thousand months ago, now 30.000 thousand. |
| 08.05.2020 18:55 | # 8 |
1.6's are usually 110 hp I have 307 2005 model 1.4 90 hp
| 08.05.2020 18:55 | # 9 |
The first impressions I bought the vehicle seemed fine, but I had megan before, when you passed the road from Kasis to the island, it was not as loud as this, but the 307 was faster and wider than that. The trip computer is a little bit simpler than megana no rain sensor, no headlight sensor is harder than my previous vehicle and the steering is stiffer than megana for now they have caught my attention that there are 307's own sound system very good compared to my old car. I bought a little bit expensive, actually it was 28,000, but when I said the car was 82,000 km clean and it was about to end up in traffic at the end of 2007, I said it is hard to find a clean vehicle in the market, let me not bother any more :))
| 08.05.2020 18:55 | # 10 |
best wishes. I hope you use it without any trouble and accident. diesel 90hp right vehicle? what is the exact model? |
| 08.05.2020 18:55 | # 11 |
Thank you .. Yes diesel 1.6 90 hp |
