I think my vehicle is frozen. It doesn't work right now. (Resolved)
08.05.2020 18:59 # 1
Eric Cartman
I parked my car, which had no problems for 2 months, in front of the house last night. In the morning, when the indicators started at -4, when I started, the car didn't work loudly. The engine water cap was constantly leaking water. At night, a drop of water leaked from the cover and an ice ball like a tennis ball was formed. There is no anti-freeze in the vehicle and I think there is icing in the water container.
The video says it all.
http://www.youtube.com/watch?v=ugipsfatdky
What happened to this car, how can we save this car :-\
* 2006 Peugeot 207 1.4 HDI
Eric Cartman 2015-01-14 20:03:04
08.05.2020 18:59 # 2
muro_60
If you eat the engine, you can think of it, don't you think it will be an anti-scratch in the car and the diesel world will cost you, be careful not to press the water caps to the ground, do not hit the ground.
08.05.2020 18:59 # 3
pusutr
Do not crank until the water inside melts!
I am officially gone.
08.05.2020 18:59 # 4
albayman
Does the starter motor gear hold the flywheel and peel off? how does this sound come from
Even if the air temperature does not fall below zero, antifreeze is a must in summer and winter.
08.05.2020 18:59 # 5
Eric Cartman
Actually, there was antifreeze, but I had to make several water supplements because of the water leak that we could not detect in the engine. For this reason, the antifreeze ratio has dropped almost negligibly.
But in this way, I learned that the water leak was from the radiator cap. When the lid missed water, it moved inward on ice. Let me figure out this freezing job and I'm going to put on a new cap right away.
Right now I left the vehicle with the radiator cover open, on a narrow side street that we think would be 1 2 degrees warmer than the car park where it was located. If the ice expands at night, I will throw it out of the cover. Cry
08.05.2020 18:59 # 6
BG307
As if the battery is dead, teacher.
08.05.2020 18:59 # 7
Mesut48
I gave my car to brother-in-law and walked in the morning,
Now the circulation in the repair shop has exploded. I don't know what's more.
These colds ruined us :)
08.05.2020 18:59 # 8
ahmet_bjk
Get well soon
08.05.2020 18:59 # 9
samet206
I have had an antifreeze in the past, but I said, I did not use the vehicle, I said, I do not use the vehicle, since it snowed, I cleaned and started last night since it snowed, but it did not control the water container by heart.
08.05.2020 18:59 # 10
suppor
Tonight, I opened the door of my ice celebration car first, then I cleaned ten mosques, made ice and water, and then opened it
I went into it, I made a black and two times, I pressed the key and then marsa 2 times chicks made chickspofpof :)
I guess that pofurt is cold :)
Then, at the gas station, I melted the ice on the pressurized water.
The water on it is now ice, cold weather, I took a little tour Drift I did in the empty area then I pulled the house to him
By the way, since I watched this video before I started mars, I looked at the water first, there is no frost,
08.05.2020 18:59 # 11
Barbar_35
The engine has also frozen. Buzz until marrow. When Mars is forced, the timing siyirms do not appear in the block as if they could save with valves. Insured comes to your vehicle at the lowest cost.
08.05.2020 18:59 # 12
yawruaslan
I don't know, I don't know if I have an antifreeze when I was in Istanbul when it was too cold. I haven't pressed what happens, my car hasn't been running for a few days now. I haven't pressed it in the starter. Do I have any problems if the weather gets a little warm?
08.05.2020 18:59 # 13
samet206
If the water freezes and dissolves, there will be no problem, otherwise it may be frozen in the battery. The failure of the vehicle does not necessarily mean that there is a motor problem. The only thing that is harmful is that the vehicle starts to start when there is frost in the radiator water.
08.05.2020 18:59 # 14
Barbar_35
Water expands as it turns into ice and detonates the engine type, this part is for him anyway, if he cannot, it blocks the block, there is no such thing because there is nothing.
08.05.2020 18:59 # 15
Eric Cartman
Many thanks for your good wishes. I wish we can get rid of this job with minimal damage.
09/01/2015
I had left the radiator cover open so that friends could have a place if the ice expanded last night. Looking at this day was exactly as I thought. The ice came out of the lid. Hopefully it didn't give the engine any trouble.
Since I cannot find a closed place where I will insert the car, it will remain this way again today. It seems that the weather will warm up to 10 degrees in Izmir tomorrow. Tomorrow at noon, when the weather is hot, I will try to heat it up with a blow dryer and stove.
08.05.2020 18:59 # 16
PARADOSK3327
hand taking garage was good time
08.05.2020 18:59 # 17
yawruaslan
I came home when the Arkadsss got a little flat today, I put on my lion again, I looked at the radiator cover and opened the water, because the water was frozen, but I did not see any freezing, I made contact with the contact door 3-4 times, I pressed the lion to feed my lion, I did not press any marsa for 10-15 days. There wasn't even that turnover shake that 106 did, he didn't even have to play it :) tableAllah the evil eye did not change :) While he was working, I did not clean his right side, I did not give any gas after 15 minutes idling, I did not give any gas 15 minutes later, I took 2-3 rounds with the vehicle for 15 minutes. Then I parked the car for another 10 minutes, I run it at idle, then I realized that I was not exaggerated by the exhaust, so the smoke was so exaggerated that I did not see it before.
08.05.2020 18:59 # 18
suppor
Today, I realized that for the first time I saw blue smoke, I gave gas without moving from the exhaust for the first time. I saw the smoke passing by me, it came to me, I pressed a little more, I wondered why the smoke was still cold, but after it gave off the gas, I wonder why it was cold: /
08.05.2020 18:59 # 19
outlaw
In the evening, I gathered all my courage and went down to the garage and immediately looked at the radiator, there was water etc, then I started to feed and started the starter, and my lion took it in the first starter, but I was not afraid in my life .
It is very normal for white smoke to come out of the exhaust because it is very cold ...
outlaw 2015-01-09 22:35:33
08.05.2020 18:59 # 20
sezar206
Do not travel without putting antifreeze, even if your naps are agalar but Izmir. Antifreeze prevents freezing in winter and boiling in summer. Antifreeze boiling writes around 115 degrees. Something 20 lira. Add two liters of water and then add water. It makes water crushes, it removes the pipes that detonate the heater core, ruins the vehicle. Water antifreeze protects in any way.
Page : / 3
