I think it burns both gas and gas
08.05.2020 20:27 # 1
aslanvar
Friends, I have a question. It has been two days since I bought my car, but when I bought it, there was half a tank of petrol, now half of the needle fell. Do you think this is normal? The model of the vehicle is 2003 xt premium in-line lovato.
08.05.2020 20:27 # 2
erdiano
No worries in your vehicle. In 307 lpg, even if the vehicle is used in LPG, the petrol indicator drops. From time to time, it rises back to its original level. I also have a little bit more gas from the tank. The indicator falls off so that it does not light up red, it comes back on its own. When it was less than half a tank, it descended until it turned red. Nevertheless, throw away 10-20 pounds of gas and try. When it comes to gasoline, it should be at a normal level.
08.05.2020 20:27 # 3
betaser
my friend erdiano explained beautifully. This situation is very normal. Thanks to the sensor located on the rear wheels of the Peugeot 307, the vehicle's brain assumes that the vehicle is driving and the average fuel is burned as long as the wheel rotates, and the gas gauge is gradually falling, even though gas is not consumed (although gasoline is not consumed). You have to get used to this situation.
08.05.2020 20:27 # 4
runiy06
All the authors have explained it very well, let me explain :)) I have 206 lpg in my petrol, my gas is always over half a tank, it is best to keep gasoline in half a tank anyway.
there is no problem for these peugeot brands to adapt to the tube, but 90% of these brand vehicles go to LPG, but they see themselves going to be gasoline, and the dropping is falling. I don't have the same problem. When the pointer rests on 0, you stop the vehicle, for example, when the morning starts, the hoop is halved again. sometimes it does not come out, even if you throw a gasoline of 5 lira for peace of mind, the hoop will come back. According to my master, there is an apparatus. If we put it in the gas tank, if we burn it, it will never come down to the tank, but there is no need for a piece that deteriorates quickly.
good forums.
08.05.2020 20:27 # 5
runiy06
As a note, I traveled 10,000 km in 2 months with half a tank of gasoline. My gasoline went down to the tube immediately, because we were in the summer in 1 line.
08.05.2020 20:27 # 6
hozer33
Well, if the tank turns red, how many km will it take: ?? !!
08.05.2020 20:27 # 7
[QUOTE = hozer33] Well, if the tank turns red, how many kilometers does it take: ?? !!
around 40-50 km depending on traffic
