I think I am troubled about the system I had.
08.05.2020 17:32 # 1
efesbright
friends 1 month ago, I wanted to have a small sound system and my budget was 1800 something. We entered a shop that makes a sound system etc. that a friend of mine knows. I told the man exactly how I wanted the sound system, I said I didn't want the sound to sizzle. The room is okay, I will do it. You just listen after you do it, and he said a little more. Then I saw which brands to wear. I suspect that I knew more or less the brands. I said why do you wear audiomax or roadstar? I will make quality sound from them. and when I say if you say the prices separately, it did not say it .. as far as I learned from the internet; roadstar companent 80tlhertz speaker 200 tlamfi 130 tl subwoofer 225tl cables 50 tl desekmontaj 100tl sayek705 is off, I gave 1000tl this is not a problem anyway, I guess we won't trust it because I think we know it. I guess they call the front door compenant.It installed the Roadstar brand team. kicker 30cm a subwoofer I do not know the details of it exactly. system in brief: roadstar compenent hertz rear door speaker + treble li.audiomax 4 channel 1600 watt amfikicker 30cm subwoofer and also i got kenwood multimedia player for 800 tl with touch bluetooth feature etc. My problem was that the sound came to me after I installed them that day because I did not know what kind of sound I expected, so I didn't have a car with a sound system before. I liked it when I say bass or something and I said okay problem, but today's complaint is something that a couple of friends say. the sound behind is better. The sound is very thin, except for the sizzling. The original speaker was better than the roadstar. I guess the speaker is insufficient according to the treble, although I made the treble adjustment from the equalizer -7 .. and another detail is the amphitheater of the front companents. They said they attached hertz to the tape on the back, but the sound on the back is clearer and of higher quality even though it is connected to the 'hertz' tape. If I tell you the sound now. bass is very good quality there is no problem there is not enough distortion in the back, but the sound in front is thin and it makes it sizzle when I raise the sound. Do you think we've stunned my roadstar speaker or doesn't it support the amp? If I buy another companent, does it support the amp? and I gave 1000 pounds to this sound system, do you think it is more? I'm so confused now that I don't know what to do. Would it be enough if I change the amp and companents or change the companent. Is there a companent that you can recommend to me that the sound that the amplifier can support will not be distorted.
08.05.2020 17:32 # 2
reality59
I use the same roadstar component, I have no problem, I got the direct tape connection, I use double din tape with 50w x 4 mosfet output.
08.05.2020 17:32 # 3
hsnsnl
If you want to do this job, my teacher will cut the money and all of them must be in harmony with the cables. This is important. pıoneer double din, powerbass amplifier, powerbass 2set compenant top series, powerbass bass .. 100tl flared on cables .. need to adjust both brand and balance good
08.05.2020 17:32 # 4
efesbright
no I have no problem with my multimedia player, bass, hertz speaker on the rear doors .. this is the heavier tweezing of the front treble than the roadstar speaker on the front door. & nbsp; ultimately the companent team but the treble sound comes out even if the setting is -7, the speaker is weak compared to the treble. and when I turn up the volume, the speaker in the front door is distorted in the sound. & Nbsp; no problem on the back .. hertz speaker on the back is playing very well ... my problem is we hit my roadstar speaker or the amp could not feed it ..? because it is connected to the hertz confirmation on the back door, it gives better quality sound and does not deteriorate. fine. but the sound in the front companents is clear and obvious. My problem is the amplifier or roadstar companent should I change? & nbsp; I am thinking of replacing the companent, but this time there is an audiomax 1600 watt 4-channel amp. Will this new purchase remove the companent? Do you have suggestions as a companent
08.05.2020 17:32 # 5
herry
I think your amperage output is not enough, if you took it to the place you bought and tried to listen to your distress, let's see what they will answer, and you will draw your way accordingly.
08.05.2020 17:32 # 6
Alicilik
I think listen to tweet and woofer tones in component systems in other vehicles. They do not sound the same tone. Hertz on the back is very good, but roadstars should not be thrown away. If you say that the kicker bass in bridges and says good, those amp roadstars should jump. I say, have your settings checked again and the eco setting on the tape is also important. Reviews
08.05.2020 17:32 # 7
kaderim@61
First of all, the sibling has drawn a separate audio cable for the myths in front, whether it is connected to the skin, or if the myth is parallel, if it is connected to the dead, it will suffocate the myth and the bass separately. The recommendation is to use kenvod or ponyner in myth and columns, the press is good but it hits a little hard. It is not eaten by someone who knows the bass setting from the amp. Let me give you a plumbing price: kenvood new series bass 270 tl with the cabinet 30 cm edison amphitheater is making alpine for the disintegration of 170tl pionner tape 8350 450tl kenvood mit 18cm 120 tl I got this system in my car and I get that number sound. respects.
