I spend 80 kurus per km
08.05.2020 18:15 # 1
ozzy_0703
Good evening, friends peugeot 106 Quicksilver I have a car, I don't have LPG in the vehicle and I have 80 cents per km, I spend 60 cents on the long road, I changed the spark plug oil filter to the computer, I had the exhaust values very high. There is nothing left to see. Finally, I have a problem with idling in my car, and it stops my feet when it comes out of the gas, sometimes it goes up and down by itself. Does the idling problem affect the fuel?
08.05.2020 18:15 # 2
VLKNYKSLN
Technically, I don't know what the reason is if you stop, but every time you stop and start the car will spend 2 times more fuel.
08.05.2020 18:15 # 3
volkan306
This may be caused by the ignition coil. Is there any improvement when the tool is not used for a few days?
08.05.2020 18:15 # 4
kuscu38
Look at the idler adjustment valve, clean it, if you don't keep tuning, you say that you have replaced the spark plugs, then look at the coils and burn twice as much fuel for every start that the friend says, as the vehicle runs unevenly, this will affect the fuel negatively. idling regulating valve + throat throttle + ignition coils respectively. ! ! Is the air filter clean?
08.05.2020 18:15 # 5
TuNeR_32
[QUOTE = kuscu38] look at the idle adjustment valve and make it clean, if you don't keep adjusting the spark plugs, you say that you have changed the wires, then look at the coils and burns twice the fuel every time a friend says, as the vehicle runs unevenly, this will negatively affect the fuel. idling regulating valve + throat throttle + ignition coils respectively. ! ! Is the air filter clean? [/ QUOTE]
The friend has written the things that are necessary, but I think your problem is that the oxygen sensor reads the values incorrectly and sends them to the brain when this sensor breaks down. The Buddha makes your vehicle work with a rich mixture. Get well soon
08.05.2020 18:15 # 6
volkanC2
You are not alone, my friend .. :) mine is very close to yours, there is no problem in idle, I thought it would be bad, but I shared the fuel with a lot of catalysts, finally, I show the car to the master and make it like to try to make it like a computer.
08.05.2020 18:15 # 7
kuscu38
[QUOTE = volkanC2] You are not alone, my friend .. :) mine is very close to yours, I think there is no problem in the idle, but I thought that the high catalyst would be obstructed, I finally shared it with friends here, finally, I show the car to the master and connect it to the computer. I will do something when I find the opportunity. [/ QUOTE]
LOLLOLLOLLOL As he said in his friend, the reason I asked for the air filter was the friend exposed. :)
08.05.2020 18:15 # 8
rizeli_53
My brother is officially burning fuel like a truck. :))))
08.05.2020 18:15 # 9
ozzy_0703
No there is no improvement, always the same
08.05.2020 18:15 # 10
ozzy_0703
Yes, the air filter is clean.
08.05.2020 18:15 # 11
ozzy_0703
I hope it will be better for you :) or we will return to public transport :))
08.05.2020 18:15 # 12
volkanC2
I went to the master today, there is no problem, thank goodness :) no stop, keep burning :)) Since the weather is cold, we will check the fuel when it is normal and when we make a long road with hot engine as much as possible, we will check the fuel. volkanc2 2014-02-01 23:43:20
08.05.2020 18:15 # 13
ozzy_0703
:)) If you don't have it, we don't have it, so let the gasoline burn tires :)
08.05.2020 18:15 # 14
volkanC2
[QUOTE = ozzy_0703] :)) If you don't have it, we don't have it, so let the gasoline burn tires:) [/ QUOTE]
oh oooohh :))
08.05.2020 18:15 # 15
[QUOTE = ozzy_0703] Good evening, friends peugeot 106 I have a Quicksilver vehicle, I don't have LPG in the car and I am 80 cents per km I have 60 cents on the long road, I changed the spark plug oil filter to the computer. There is nothing left to see. Finally, I have a problem with idling in my car, and it stops my feet when it comes out of the gas, sometimes it goes up and down by itself. Does the idling problem affect the fuel? [/ QUOTE]
Idle sender seems to need cleaning
08.05.2020 18:15 # 16
ozzy_0703
08.05.2020 18:15 # 17
ozzy_0703
I think it was the same again 2 days later, I think it should be replaced with a new one
08.05.2020 18:15 # 18
[QUOTE = volkanC2] I went to the master today, there is no problem, thank goodness :) no stop, keep on burning :)) Since the weather is cold, we will check the fuel when it gets normal and when we make a long road with hot engine as much as possible .. [/ QUOTE]
Volkan `` I swear '' is psychological, it came to me like a psychological .. okay it does matter but it doesn't matter Cry
08.05.2020 18:15 # 19
[QUOTE = ozzy_0703] Cleared I think the same happened again after 2 days I need to replace it with a new one [/ QUOTE]
it contains a gasket-style plastic inside it, change it first, if you don't try your chance, unfortunately you will have to replace it with a new one. The reason for this error is the sportive air filter.
08.05.2020 18:15 # 20
ozzy_0703
Thank you, I will check it on Monday.
Page : / 2
