I RUNNING THE VEHICLE BUT ... EMERGENCY AID
08.05.2020 18:34 # 1
preadator06
Hello friends, I broke the vehicle as of today, but a job has happened to me. As seen in the pictures on the rear fender, one person is rubbing when he sits ...
In addition, while 1 finger enters the rear left fender of the vehicle, 1 finger enters the rear right arena, I can not understand it either ...
I researched that I had to expand the fender mouths. I am looking for someone who does this job well in ANKARA. Can you help me ...
In addition, I installed a 50mm spring on the vehicle and lowered 1 tooth on the rear torsion I got the tires today 185-55-14 ...
preadator06 2014-05-23 22:37:51
08.05.2020 18:34 # 2
Serkan
The fronts are good, but the back is seriously down.
08.05.2020 18:34 # 3
preadator06
[QUOTE = Serkan] Prevents are good, but back is seriously down. [/ QUOTE]
Yes, the master avoids exactly what I wanted, but the rear fenders are very pressed ... I don't know how to do it?
08.05.2020 18:34 # 4
Serkan
How was it before I dropped the torsion? Much of it remained in the air, it looks as if it hadn't descended.
08.05.2020 18:34 # 5
preadator06
Yes, the master was in the air, I was not downloading it, but it was not pleasant, and it was actually in the air.
08.05.2020 18:34 # 6
okan77
http://forum.peugeotturkey.com/forum_posts.asp?tıd=34997&kw=&pıd=504672&title=lastik-surtmesi#504672
maybe you have studied ...
08.05.2020 18:34 # 7
preadator06
[QUOTE = okan77] http://forum.peugeotturkey.com/forum_posts.asp?tıd=34997&kw=&pıd=504672&title=lastik-surtmesi#504672
I have reviewed it now okan77 brother thank you ... I am glad that your friend's problem is solved, but I do not know how to solve mine on the fender:?
08.05.2020 18:34 # 8
samet206
very fallen brother back is not like 1 tooth, can this process be a mistake ...
08.05.2020 18:34 # 9
TaZ
If you find the organs jack of the hawks, you will open it up.
08.05.2020 18:34 # 10
preadator06
Believe me, I did not understand, friends, we said 1 tooth, it turned out, I would appreciate if the downloader gave information before. Also, I don't know how to open the rear fenders of these 106s.
08.05.2020 18:34 # 11
preadator06
The problem is solved ... I opened the pipe and it was beautiful, I took care of everyone.
