I replaced the solenoids and it was super.
08.05.2020 16:41 # 1
onlyyou42
A friends hello finally the electro valve and pressure sensor of 307 lions have changed.
Total price 650
4 lt yag
2 solenoid
1 pressure sensor (shift speed range calculator)
and workmanship.
My car now, thank goodness like oil I love my car. I can give the name and location of the master who makes it. (Original 14 version with the same software as the authorized service) The guys are both young and smiling and inform you with much more. There is no question mark in your mind. >
08.05.2020 16:41 # 2
Get well soon. There is no more beautiful feeling than the person getting into the vehicle with pleasure.
08.05.2020 16:41 # 3
istanbullu_3886
I get well past those feelings I know well
08.05.2020 16:41 # 4
onlyyou42
Seriously true, the car seems to be cumbersome & nbsp; It was a machine with a dewam that saw 130 km of shouting when getting up, and was left to sell.
08.05.2020 16:41 # 5
toga406
If my vehicle 406 bva pressure sensor is defective, will it cause the oil temperature indicator to rise, do you know my friend
08.05.2020 16:41 # 6
onlyyou42
When my vehicle was connected to PP 2000, PRESSURE TORQUE CONVECTOR RANGE WAS KNOWING INFORMATION ERROR. I think there is no problem.
08.05.2020 16:41 # 7
toga406
the master could not say anything. engine oil temperature was based on max. He said at the end, the sender may be corrupt. I pulled the cord right now, I don't know whether it is the problem. If the service was left, let the car one day, the sentence formed the sling.
08.05.2020 16:41 # 8
onlyyou42
What is the result of having the PP 2000 device connected? If the problem is the oil temperature sensor, replace it. It is a cheap piece. So unplugged :) :)
08.05.2020 16:41 # 9
narkotik71
friends, I changed the valves to 550 TL in the month of Ankara. I had a valve change in the vehicle 1 year ago. When the problem was repeated, the valve change was obligatory. intermittent pressure failure & nbsp; failed. 2.5 pressure value and the temperature was below 90 degrees. 70_80 degrees. Even if the engine warmed, it did not exceed 90 degrees. It was faulty. . & nbsp; & nbsp;
08.05.2020 16:41 # 10
106fb
[QUOTE = onlyyou42] A friends hi finally the electro valve and pressure sensor of 307 lions have changed.
Total price 650
< / b>
4 lt yag
2 solenoid
1 pressure sensor (gear shift speed calculator)
and workmanship. I can give the name and location of the master doing this job in the world. (The original 14 version is with the same software as the authorized service) The guys are both young and smiling and inform you with much more. There is no question mark in my mind. I love my car now 2 times more. Regards ..
I would appreciate if you write the name and address of the master & nbsp; I'm in Konya too
08.05.2020 16:41 # 11
carantinas
Oil leakage of solenoids causes problems with gear changes and makes the car bulky. and the car constantly put itself in protection mode in 3rd gear. & nbsp;
08.05.2020 16:41 # 12
onlyyou42
konya peugeot efe karatay industry.
08.05.2020 16:41 # 13
ekinoks44
the price seemed a little too much to me though. good luck bro
08.05.2020 16:41 # 14
onlyyou42
cellonoid grain 110 lira (2 pieces)
4 liter mobile transmission oil 80 lira
1 pressure sensor 200 tl
labor 150
total 650tl
08.05.2020 16:41 # 15
peugeot22
The automatic gearbox used in the Peugeot is really successful and less expensive than the others.
Cellonoids are generally a problem, but it is a problem that both comforts you and your vehicle.
It seems appropriate in price.
Good bye.
08.05.2020 16:41 # 16
emrefe
friends in my car & nbsp; automatic gearshift when I stop in traffic, the car is locking itself and then pushes forward 20 seconds later, what is the reason?
08.05.2020 16:41 # 17
kudret_yildirim
the pressure sensor was pretty good. I was thinking too, but he would enjoy it. I was saying I'll change because of km. kudret_yildirim 2012-04-06 22:31:12
08.05.2020 16:41 # 18
kuantum
[QUOTE = onlyyou42] cellonoid grain 110 lira (2 units)
labor 150
total 650tl
How do you know if the
pressure sensor is faulty?
08.05.2020 16:41 # 19
EnSoNiQ
I think it is time for maintenance, I guess knock started in gears, let me connect it to a little computer.
08.05.2020 16:41 # 20
fexzi
Let's get the number of the master from Konya specially please ..
Page : / 2
