I replaced the key battery
08.05.2020 18:04 # 1
gebedek
Hello friends. My car is 206 x-line 2005. I changed the battery of the key myself last night. The car did not work in the morning.
-Remote opens the doors remotely, turns the ignition, the starter sounds but does not ignite.
Could the vehicle not work due to this battery change.
What would you suggest about the solution?
08.05.2020 18:04 # 2
Brother, there is an immobilizer in the key, did you drop it somewhere or something? Battery replacement does not cause trouble.
08.05.2020 18:04 # 3
gebedek
Mr. Doğan, thank you for your interest. Into the immobilizer. I even had the screw through the middle of the circuit. Should I introduce it to the car again. If I said the circuits were damaged, no such thing happened
08.05.2020 18:04 # 4
You're welcome. I don't think so, I know that because I have changed, nothing has come to print. This does not disengage circuit only for central lock. It connects the vehicle with the immobilizer. Even if there is no battery, you can open the doors and start the engine. It seemed strange to me. Take a look at introducing the key from the handbook, there is the necessary information.
08.05.2020 18:04 # 5
eren106
Check imb.
08.05.2020 18:04 # 6
eren106
tiny chip in sand.
08.05.2020 18:04 # 7
gebedek
08.05.2020 18:04 # 8
gebedek
Is the piece you are talking about is the smallest rightmost piece. If these parts are installed correctly and the doors are controlled, do you need a re-introduction?
08.05.2020 18:04 # 9
Yes that piece is immo.
08.05.2020 18:04 # 10
eren106
cchip contact key
08.05.2020 18:04 # 11
eren106
try the black chip in different ways
08.05.2020 18:04 # 12
Serkan
Do you have a spare key? If there is a spare key, try it, if it does not work with it, do not look for the problem in the immobilizer. Battery replacement does not have an immobilizer effect, even if you dispose the electronic circuit in the picture. Serkan 2013-11-15 19:15:58
08.05.2020 18:04 # 13
gebedek
I don't have a spare key. When I put the key this day, I saw that the little baby was somewhere in the nest, not in it.
08.05.2020 18:04 # 14
sezar206
pi is related only to the control of the vehicle. it does not affect battery operation. You have trouble with immo. As soon as you start. Check the immo of the key.
08.05.2020 18:04 # 15
gebedek
Thank you guys. The problem is solved. There was a problem because the chip was not seated inside the key.
