I replaced 206+ tapes, but there are problems ...
08.05.2020 17:45 # 1
berker2004
I replaced my 206+ tape with the pioneer deh-6550 bt tape, but naturally, there is no data about the songs on the center console. We knew this at the beginning, but the clock only shows when it is running correctly, it does not change as time passes, and another problem is, let's say the right door is open, the door is closed, the screen remains so fixed that it slides.
Obviously, the original tape is used in the control of this screen. Can I install the tape in an invisible place and supply the working voltage without speakers from one place?
Waiting for help from the experts of the work .... thanks in advance ... Embarrassed
08.05.2020 17:45 # 2
opasno
The cables on the back of the tape may not be properly connected.
08.05.2020 17:45 # 3
berker2004
I don't think my teacher, how do those ends enter the tape?
08.05.2020 17:45 # 4
Alicilik
Tamper with the audio systems section I wrote in two internal titles. I am out of the city.
You need to insert and insert the battery terminal with a procedure.
08.05.2020 17:45 # 5
berker2004
Alliance brother, you are an expert in this business.
Or I couldn't find the title, can you give me detailed information at a convenient time.
is something you can build. I'm tired of fainting money, tape recorders
08.05.2020 17:45 # 6
berker2004
I found the subject, but the battery disassembly is related to a look at the engine or is it related to another socket
08.05.2020 17:45 # 7
berker2004
How do I reset the clock when it is removed? tape changed :(
08.05.2020 17:45 # 8
howard
we can not put double tape on this 206 or ztec double tape.
08.05.2020 17:45 # 9
Alicilik
Hello my teacher,
You open the top left windscreen and hood.
You stop the vehicle and turn off all the parts that will draw electricity.
Wait 3 minutes and remove the + terminal of the battery terminal.
You wait for 1 minute and put it back on.
Wait about 1 minute and turn on the parking lights without opening the door.
The vehicle will snap and come back.
Then the screen gets better.
Don't worry if you don't use 3 lines. Use the new tape directly. You can set the time and date directly from the screen, not like the 207s.
receptivity 2013-06-30 20:39:51
08.05.2020 17:45 # 10
Alicilik
[QUOTE = howard] Can't put double tape on this 206 or I have ztec double tape left. [/ QUOTE]
my teacher is putting double but they usually cancel the air vents and it looks very ugly
08.05.2020 17:45 # 11
berker2004
We can not do it directly from the screen. We tried the time and date setting, but I can be wrong. There is no road information.
08.05.2020 17:45 # 12
berker2004
206+ car buying friend.
08.05.2020 17:45 # 13
berker2004
Mine is adjusted from left and right keys. I wonder if a cable related to it was removed while the tape was attached
08.05.2020 17:45 # 14
Alicilik
[QUOTE = berker2004] 206+ car buying friends. [/ QUOTE]
Press and hold the key on the left of the screen. The menu opens.
The first is the language settings.
Then the date, time, 12/24 degree CF setting comes.
You can pass the settings with the left button and make changes with the right button.
08.05.2020 17:45 # 15
berker2004
I will try it now
08.05.2020 17:45 # 16
berker2004
I have not removed the plug + end of my battery friend, did I? Turkish flashing changed but I couldn't switch to date and time functions ...
08.05.2020 17:45 # 17
Alicilik
tmm is pressed the left button again passes the language menu, if you press right it changes the languages
08.05.2020 17:45 # 18
Alicilik
It has nothing to do with the battery terminal. Whenever you want, you can adjust this setting from the army keys.
If the booklet is still there, you can look there.
08.05.2020 17:45 # 19
berker2004
Here I am pressing left again, my teacher has not changed or the damn date has changed to time. Is it because I haven't done this battery event?
08.05.2020 17:45 # 20
berker2004
We looked at the booklet on the left button press button 1 dio bassoz Turkish flashing for 2 seconds. we change it with the right button, but press the number 1 button again to switch to another dio press but no use hojam passed to other settings.
For example, the left door is open and the door is closed.
and the problem that will be corrected when I take off and put on the pole is the update of the clock and this writing problem, I think, right?
Page : / 2
