I put 307 1.6 HDI shell 10W30 oil
08.05.2020 19:04 # 1
FACE
Hello friends, I had my car serviced today. There were some extras, my mind was castrol edge as oil, but since it was salty, we put shell 10w30 oil with the recommendation of ustamine.
08.05.2020 19:04 # 2
FACE
Nobody used it or does anyone have knowledge?
08.05.2020 19:04 # 3
monalos
I do not know my brother, who answers, who answers has not yet arrived, they look at the forum or something else they will look at you in time.
08.05.2020 19:04 # 4
xmen
I think don't do much trouble. after all it's a brand name shell. I don't think it will be such a bad oil. your master has already suggested. Build 1000-2000 km and you will see the result with your own experience.
08.05.2020 19:04 # 5
FACE
Thank you bro.
08.05.2020 19:04 # 6
FACE
Well normally they were 10W 40 bays but this was 10W 30 bays. What could be the difference between them? This oil warms faster than I observe during the day.
08.05.2020 19:04 # 7
KIZILASLAN
I know that it is not 5/40 instead of 10/40 that I know
Don't worry about it, I put the first selenia, then I put castrol edge turbo diesel, no difference. now I put selenia again
08.05.2020 19:04 # 8
FACE
Let's use it, is there really no difference between castrol and selenia? How many Selenia did you put? FACE 2015-02-08 01:58:22
08.05.2020 19:04 # 9
xmen
[QUOTE = FACE] Well normally 10W was 40 bays but this was 10W 30. What could be the difference between them? This oil warms faster than I observe during the day. [/ QUOTE] I don't know what the difference is between them, but it is better to warm up quickly. you will say why, the car burns more fuel until it gets hot. quick heating of the oil will reduce fuel consumption (my humble opinion) :)
08.05.2020 19:04 # 10
FACE
You are right. I investigated a little bit, the situation looks exactly as you described it. Thank you. FACE 2015-02-08 02:06:37
08.05.2020 19:04 # 11
xmen
You're welcome. we try to share what we know as much as we can.
08.05.2020 19:04 # 12
KIZILASLAN
[QUOTE = FACE] Let's see, is there really no difference between castrol and selenia? How many Selenia did you put? [/ QUOTE]
There is no difference to feel between. Selenia 5/40.
08.05.2020 19:04 # 13
FACE
Let's see, we will understand the difference after 1000 2000 km. Thank you.
08.05.2020 19:04 # 14
BLACK LION
FACE I went into maintenance yesterday I had Shell 5w-30 installed. There were 10w-30 10w40 for 70 pounds, they usually put it on everyone. I know it is already for 10w40 gasoline, which is put 30 in diesel, but it should not be wrong. . I gave 30 pounds more, I put it well. the engine was even more agile and quieter. these are a little thinner than normal, making lubrication quicker, for example, thick oils in winter become heavier and thicker. For this reason, fine oils provide easy lubrication during the cold and the first start. Also, a feature of the oil we use is, for example, when the engine does not work at night, even if the oil goes down to the sump, it prevents the engine from running oil until the oil comes up from the sump in the morning and prevents wear. so the difference between 5w-10w is not very important. The important thing is that the value on the right is 30, which is already correct. There is not much difference in good oil shell. By the way, how long has it gone? I am diesel: I changed the air oil filters and shell oil to a total of 275 TL. filters are the original peigeot brand.
speedy 2015-02-08 06:34:00
08.05.2020 19:04 # 15
FACE
I gave 230 TL excluding diesel filter. However, the extras came out, ten and rear disc pads (375 TL), injector cleaning and gasket replacement (180 TL familiar price), and totaled 820 TL.
08.05.2020 19:04 # 16
monalos
they say they are supposed to have a 5w30 oil now but I think it would be good if they put 5w30 in my new 12-13 year old car, because I think it would be 10w40 for foreigners.
08.05.2020 19:04 # 17
korkusuz202
Since my current oil was castrol 10/40 and my previous oil was at km 162, I added 10/40 instead of 5/40. In my opinion, the performance of the shell was not bad, its oil was not bad.
korkusuz202 2015-02-08 13:50:11
08.05.2020 19:04 # 18
SDYMZ
My teacher on the internet http://www.n11.com/total-quartz-ineo-ecs-5w-30-4-litre-motor-yagi-2014-dpfli-P20175221
http://www.n11.com/total-quartz-7000-10w-40-4-litre-motor-yagi-p17000376
It is convenient I always buy from here and there is also an installment Smile
SDYMZ 2015-02-08 16:10:54
08.05.2020 19:04 # 19
italian
i ded 2008 got 307 feline 1.6 hdi i put 5w 40
08.05.2020 19:04 # 20
italian
original oil total elf
