i need your information
08.05.2020 20:14 # 1
42kaan
Hello friends
I have the 2005 premium 307. I bought it 2 months ago. I am facing some problems.
1-) the brake sensor sometimes does not fulfill its duty. 2 times I replaced it with the original one but did the same thing.
2-) I turn the ignition, the lights are on but the starter does not. As a solution, I change the gear from position d to p.
I would be glad if you show solutions on these issues.
good day everyone.
08.05.2020 20:14 # 2
Hello
First of all, welcome to us.
1-brake sender may be a bit difficult to install in case of a permanent malfunction.
2- The part I gave the link may be defective.
Of course, before that, I recommend you to connect the teacher PC and have the fault code checked.
08.05.2020 20:14 # 3
talip206
1. The problem seems to be related to use, but replace the brake sensor with the original one. The place that sells the sub-industry is very much because it is original in the market.
2. A normal situation. because the safety automatic transmission vehicle does not work in gear. works only in the N and P positions. that is normal.
You're new in automatic gear. Do not stop at d while stopping your vehicle. I think this is the source of your brake sensor problem.
I recommend this when stopping for the life of the transmission,
1.Shift the handbrake to N before stopping.
2. Take your foot off the brake, so that the load of the vehicle is put on the parking brake.
3. Press the brake again and take the vehicle to P.
4. Stop.
make it a habit.
talip206 2017-03-06 12:24:51
