I need your information ....
08.10.2020 10:21 # 1
Emr2424
Hello friends, when I turn the right signal in my car, the rear wiper works. What is the problem?
08.10.2020 12:08 # 2
Hello teacher, there is probably a problem in the wiper arm.
08.10.2020 13:49 # 3
Emr2424
Electricity is coming, I give water but although it does not throw
09.10.2020 08:45 # 4
When the parts inside the arm are worn, you can encounter such problems, sir. Even if no water comes out, the spray nozzle may be clogged. or deposits that accumulate at the bottom of the wiper water tank can clog the rear squeegee water hose.
11.10.2020 00:22 # 5
bykeskinofk
I also experienced the problem of not getting water There may be two problems, the first is that the glass water pump has reached its end of life. The second may be clogged. I solved the problem by disconnecting the hoses and opening the blockage with compressed air.The reason for this blockage was due to the use of hard water.
