I NEED YOUR HELP
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 508
24.06.2020 21:31 # 1
Eko55
Friends, hello everyone, I just joined you. I bought a 2013 model 508 E-HDI Auto6r at 180,000 km. The subject I need your help is; When I switched the gear of the vehicle to "A" position, just before I took my foot off the brake and hit the accelerator, the vehicle started to move with a thump. He was moving by shaking. But he didn't always do that. He was doing it every 2-3 days. I asked a few masters, they do this because the pressure lining starts to wear, they said "Adaptation" need to be adjusted. I made an adaptation adjustment, and the problem of shaking action was eliminated. However, before the Adaptation adjustment, the vehicle was making progress on its own, even though I did not take my foot off the brake and give the vehicle gas while the gear was in the "A" position. This makes it very convenient when parking. After the adaptation adjustment, the vehicle does not advance, it is necessary to accelerate for progress. Why would this happen? I want it to proceed without gas like before. I would appreciate it if you inform. Thank you. Eko552020-06-24 21:35:32
25.06.2020 09:10 # 2
First of all, welcome to us fellow countryman. Good luck for the vehicle, it is because it is after the adaptation, and it is because of the hill start support in your vehicle. There is no problem with my 308 owner vehicle, which has the same transmission and engine.
25.06.2020 09:15 # 3
Eko55
Thanks for your answer. I think you are from Samsun. Could you recommend a master / special service in Samsun who understands these gearboxes?
25.06.2020 09:19 # 4
I am from Samsun, my teacher, and I am from Ladik district. but I live in Ankara. Samsun has never come across a good master in industry until now. We even brought your uncle to bmw ankara, where they charged 10000-15000 TL for the transactions we made 8000 TL. Of course, there are still good masters, we need to research one by one.
25.06.2020 09:21 # 5
Eko55
Thank you my friend. Thank you very much.
25.06.2020 09:24 # 6
I would like to help you if you were in Ankara, but unfortunately, as I said. We couldn't help but be sorry, sir. Have a nice day
15.10.2020 13:41 # 7
fatihd
Hello, about three months ago, when I first looked at 508, it was making progress without gas, but the pressure plate of the vehicle was knocking, we could not agree and we looked at another vehicle, this time was renewed, but as you said, it does not progress without gas. The truth of the matter is that even if it is semi-automatic, one expects a slight progress, and also because of the start stop, the engine stops quickly when the gas does not give off. What did you do? Did you find a solution? I wondered.
15.10.2020 13:53 # 8
Eko55
My problem is because the lining is finished.
25.10.2020 17:06 # 9
fatihd
I am glad that you solved your problem, but I was surprised, as a matter of fact, the pressure lining was exhausted in the vehicle that I did not work for, but there was excessive knocking, but the vehicle was moving without gas, there was no problem in the vehicle I bought, but it does not. In addition, I have a complaint about the start-stop, the vehicle starts up without hesitation, and sometimes even when turning right and left, I wondered whether it might have something to do with your speed as well. I wonder how much the pressure lining flywheel workmanship cost, thank you.
28.10.2020 08:59 # 10
[QUOTE = Eko55] My problem is because the pressure lining is finished. I changed the pressure lining and flywheel set as a set. After the change, there was no knock left and it is driving without gas. For start-stop, you can disable the start stop. [/ QUOTE] If your problem is solved I'm glad teacher.
27.12.2020 16:20 # 11
Glemurri
My vehicle 2011 vti acces auto6r moves without gas after 2012 as told to me 2011 curtain does not have that feature, it is true that mine sometimes knocks and does not go without gas.
