I NEED HELP!
08.05.2020 21:15 # 1
erendoqru06
good evening good evening my 207 premium vehicle sounds like a rubbing sound in 1st gear at 2000 gears, cuts when you press the drain or disengage. erendoqru06 2019-06-10 21:16:00
08.05.2020 21:15 # 2
ismailkaya
there is a ball in the drain set, it can make sound or transmission gear
08.05.2020 21:15 # 3
As our friend said, the transmission ball is troubled.
08.05.2020 21:15 # 4
serkan066066
The gearbox ball is scattered. He was doing the same with me. When it goes at high speed, it starts to make hum. Estimated price reaches 1000 TL including labor
08.05.2020 21:15 # 5
erendoqru06
Thank you for your priorities. After the 3rd gear, the sound is cut off. I did not hear anything in the high faces.
08.05.2020 21:15 # 6
serkan066066
I think the sound is not interrupted, it is not heard when the high girl goes, then the sound becomes evident at high speeds.
