I need an urgent answer
08.05.2020 16:11 # 1
wldnsxc
I have a 206 gti vehicle, I need an urgent spiral. My question of 5cm is that I fit all 206's. I found a comda from the 5cm spring owner.
08.05.2020 16:11 # 2
I Didn't Understand The Question ..
08.05.2020 16:11 # 3
wldnsxc
Can we use the same sports springs in all of the 206's gti feline xdesign
08.05.2020 16:11 # 4
Man Sells Which Vehicle Is Using The Broadcast ...
If 206 Vehicles Are Using It Also Fits Your Vehicle ....
08.05.2020 16:11 # 5
wldnsxc
206 eibach 5cm using 135tl is suitable?
08.05.2020 16:11 # 6
[QUOTE = wldnsxc] 206 eibach 5cm using 135tl is suitable? ... if you want ...
08.05.2020 16:11 # 7
wldnsxc
need urgent landed at 110
08.05.2020 16:11 # 8
Take It Then;
If You Call It Urgent ... I Wouldn't Give Second Hand Pedestrian Money ...
Come on, Good Luck Whether ..
AlbaYDemircaN 2011-10-01 10:19:49
08.05.2020 16:11 # 9
wldnsxc
thanks .
08.05.2020 16:11 # 10
It is more reasonable to take zero zero as much as the second hand.
08.05.2020 16:11 # 11
eibach 3.5 cm, you will not regret ..... If you get 5 cm, you will always have a front team ...
08.05.2020 16:11 # 12
It will be 5cm harder ... It will naturally lead to faster mechanical malfunctions ...
08.05.2020 16:11 # 13
OkaN
pilgrim you broke your head immediately & nbsp; 5lik & nbsp; "Grin"
08.05.2020 16:11 # 14
get off :)
08.05.2020 16:11 # 15
cash1912
I found the zero of 240 where I said the price will be 35 mm but
08.05.2020 16:11 # 16
cash1912
my colonel, I asked you this question
08.05.2020 16:11 # 17
tigerland
[QUOTE = by_ersin] eibach 3.5 cm, you will not regret ..... If you wear 5 cm, you will always have a front team ... I will give you a recommendation from me ... [/ QUOTE]
I'm using 60mm which will be 1.5 years I had a check up last week, oil levels, oil life, the front team, the back team, there was no problem in the front team, thank goodness :)) there is only a small gap in the torsion ..
