I Need 308 Advice
08.05.2020 20:43 # 1
retina
Friends.
First of all, I wish you good forums. I hope 2018 will bring abundance and peace to everyone.
I am thinking of buying the following vehicle. But I need your guidance.
https://www.sahibinden.com/ilan/vasi...9448560/detay/
Vehicle: At 93,000 ...
There is a Sport Bow on it.
What is your advice? How do you think?
Are there any people who know this tool from the forum?
Does Sport Spring create comfort problem?
Thank you in advance for your valuable answers.
08.05.2020 20:43 # 2
samet206
Hello, the vehicle looks neat and it has caught me when I saw the rims that I like very much and that suits the 308 most. If it has been dropped so much, there is a possibility of rubbing at some points, it may not go to every road like this, it is necessary to look for rubbing when it is full. I say good luck ...
08.05.2020 20:43 # 3
Ahmetaltan
First of all, I wish good forums. The vehicle you will buy is already good. Although we are not sure when it comes to the vehicle you like. I do not think I am sportive as it was written on the advertisement. Sportium should also have features such as glass roof, digital air conditioning, sportium wheels, white indicators, original armrests. Other than that, beautiful tool.
08.05.2020 20:43 # 4
Exactly the vehicle is not sports, but the acces model only made the slightest minor changes. You may know that the engine is not 112 and be informed. you need to look good
08.05.2020 20:43 # 5
pusutr
This vehicle acces package 92 hp.
No glass ceiling - no digital air conditioner - no led daytime running lights - no org armrests - no auto-dimming and no rear-view mirrors with a display.
Apart from that, I think the painted parts are not painted for cleaning purposes but because of the accident.
Sport springs do not suit this vehicle in my opinion. And it will significantly reduce comfort.
Finally, although the color is a beautiful color, the vehicle sells at least 10 thousand TL above its value. Of course, the final decision is yours.
Do a good expertise. Examine the final inspection sheet. And find out the damage record. Check the actual model-package of the vehicle on the license.
08.05.2020 20:43 # 6
fatihsultan
The vehicle looks very fresh and clean, but they always look like this in the photos :) It is necessary to take a closer look, if it is used in 93 thousand clean it will not be a problem. If you absolutely and surely buy an expire, I regretted it. Be sure to look at everything. Try to break the price as much as you can, bargain circumcision is finally.
But I liked the car as it is.
08.05.2020 20:43 # 7
retina
thanks guys for your reply. Indeed, the value of this tool should be 40 - 42 thousand pounds. I keep talking to the friend. If he leaves between 40 and 42, I will buy it, otherwise I will continue to look for a clean sport. why are sports only so expensive? There are 70 thousand wanting. How come I don't mind.
08.05.2020 20:43 # 8
Ahmetaltan
[QUOTE = retina] guys, thank you for your reply. Indeed, the value of this tool should be 40 - 42 thousand pounds. I keep talking to the friend. If he leaves between 40 and 42, I will buy it, otherwise I will continue to look for a clean sport. why are sports only so expensive? There are 70 thousand wanting. I don't mind how it works. [/ QUOTE] You can't find such a tool between 40-42. It can be purchased at an affordable price, with a tight bargain. Ahmet Altan 2018-01-17 01:13:57
08.05.2020 20:43 # 9
maximusti
the vehicle is alive, but it is necessary to practice it in a proper place,
Also sportium - acces you need to get exact information on which package.
The sports spring also cuts a little from comfort and if it is not used carefully, it causes problems when walking.
unfortunately, the prices of all cars are offset. but still, it seems like nobody will give the car that he wrote 52,000 rubles 42,000.
