I MIXED THE LPG INJECTOR ORDER ..
08.05.2020 21:14 # 1
cihanozcelik
Hello there,
al ..
I made the upper cover gasket ..
the man removed all the cables and gas inlets of the lpg ..
Then he put on the car is now stupid acceleration is bad .. when he gets into the gas, he's a fool
can i fix this ranking?
I'm waiting for your help..
08.05.2020 21:14 # 2
First of all welcome to us. you have to try one by one, it makes a lot of work.
08.05.2020 21:14 # 3
cihanozcelik
I did a little bit .. it was better than before but there is a click problem again .. it makes a very slight cut again ..
I think we will go to the master ..
thanks..
08.05.2020 21:14 # 4
When the top cover is made, the working order of the vehicle changes, possibly the LPG setting may be impaired.
08.05.2020 21:14 # 5
cihanozcelik
To work comfortably, all cables were disconnected from the gas inlet hoses .. :(
Actually, there was no need.
08.05.2020 21:14 # 6
cihanozcelik
Maybe it doesn't get air anymore, it may be from it .. there is no air escape ..
08.05.2020 21:14 # 7
x571
[QUOTE = cihanozcelik] dismantled all cables to work comfortably gas inlet hoses .. :(
Try LPG and give it a try. The spark plugs have difficulty even when changing Lpg on the engine. Actually, it would be better if they didn't put it there
