I'm waiting for your help
08.05.2020 21:29 # 1
Agokoren
first of all
I am among you with my 2006 model 307 1.6 hdi 110 car
I need your help in a few issues
I just bought the car, I had the oil maintenance etc. I had a traction problem in 210 thousand, I changed the flowmeter, the problem went away, the oil flows from the bottom of the injector and the oil is on the vesgate at the bottom of the turbo. There is something like a spring and gasket. There is nothing like a gasket. There is no tear in the gasket. There is no problem.
In Eskisehir, is there a skillful master who will do the right job of his job with the right job, or is there any problem that arises?
Why did some friends find the problem through the pipe, but I couldn't see the leak in the bottom pipe.
Thanks for your help in advance
08.05.2020 21:29 # 2
hard to find master of ace straight teacher. replacing the injector washers. black smoke is usually caused by injectors, and egr cleaning. turbo hoses have seals replace them. I think in your turbo etc. There is no problem in the turbo, there must be some lubrication from there. they do not fit the connections. hoses cracked etc. can.
08.05.2020 21:29 # 3
Agokoren
thank you for your comment how much does it cost to set up an injector?
The turbocharged hoses are in good condition, but the snail is like oil.
08.05.2020 21:29 # 4
it just doesn't cost much if the stamps change. But there is a situation called injectors urination, when they are all handed out, they will make a price according to the company between 800-1200 TL. Although the hoses look good, sometimes there may be capillary cracks.
