I'm waiting for your help
08.05.2020 14:14 # 1
shamed
If you can help me with the reason why it sounds silent after a short time like the sound that is sharpening the knife while driving, then I will sewinir.
08.05.2020 14:14 # 2
itouch_GTi
The pads may be rubbing against the disc. I suggest you look at the brake system.
08.05.2020 14:14 # 3
shamed
tskler hmm I understood that my pad is running out or ask my disks?
08.05.2020 14:14 # 4
MirakGTI
your pads run out, change your pads without eating discs
08.05.2020 14:14 # 5
shamed
If it makes a very rare sound, does this pad end from it, or is it another reason?
08.05.2020 14:14 # 6
itouch_GTi
It is useful to replace both pads and discs. If you have heard this sound for a long time, the discs are already drawn. If the disc replacement costs a high cost, you can grind your discs on the lathe and use them only for a while by changing the pads.
08.05.2020 14:14 # 7
shamed
No sound, very rare, or almost none of the estimated discs.
08.05.2020 14:14 # 8
rifatseker
Greetings,
If the subject is the brake system, the cost shouldn't matter much, you should definitely check it out and change the parts if necessary. Remember! as a result, only those linings and discs will stop the car you are using.
08.05.2020 14:14 # 9
shamed
No, I understood that it is a bit cramped at the moment, so I will have it checked. What is the estimated disc we have?
