I'm very surprised
08.05.2020 18:07 # 1
vodkaburnblue
Hello, good forums first;
My friends vehicle peugeot 206 1.4 x-line. Fuel consumption up to 40 cents in the city until the last week ..
My car left me on the road 3 times, I passed by saying that it will happen in the first two, but today my patience is exhausted when I run out of gas in the cold weather.
My 10 lira gasoline that I threw yesterday was not enough. Normally, 10 lira gasoline; 25 I was driving 50 kilometers in 20 lira gasoline, and I always use my car to make a book. Normally I use it in 2000 cycles ..
10 lira gasoline 3 days ago; 18.9 kilometers
10 lira gasoline 1 day ago; 16.1 kilometers
Friends, I'm waiting for your help.
08.05.2020 18:07 # 2
vodkaburnblue
Thank you for your comment. I do not say that I can not throw 10 lira of 20 lira gasoline and break it in my money :) Do not get me wrong.
There is no birded LPG in my car, known gasoline is 5 lira, garci was 3 lira in lpg. Do you think I should have lpg or should I say that there is not much difference and continue the gasoline.
08.05.2020 18:07 # 3
kursat3006
I think there is no point in entering the lpg event from that time
08.05.2020 18:07 # 4
C@GL@R
Do you need 10 liras of gasoline or sell your car or buy an electric bike, get on it: D Buy 50 liras, see a quarter, go to the gasoline when it comes to the bottom line.
08.05.2020 18:07 # 5
volkanC2
In my last calculation, I have 60 cents of fuel, 1.4 gasoline C2, I changed the spark plugs on the weekend, I set the valve-valve (how it says now) :) and I bought 100 pounds of gasoline. until :))
08.05.2020 18:07 # 6
You may have damaged the petrol pump, (take 100 TL for once in the tank, come to the half tank, then get 10-20 TL for fuel this time as it falls into the quarter. Somehow you always think of a quarter prank as 0. and you get 10 TL (you get more and more efficiency).
08.05.2020 18:07 # 7
vodkaburnblue
I thank you all for your comments. I will consider your suggestions :)
08.05.2020 18:07 # 8
kuscu38
Hodja, if you always buy the gas you want, 70% of the possibility of burning the gasoline pump :) I think 40-50 lira to buy the most, both the pump will not be damaged and we will not forget, friends, if you buy more fuel, you will make more miles, you will adjust the vehicle according to the gas you bought.
It stays in the tank, the dirt is going on, all of them damage the vehicle over time ... LOL
08.05.2020 18:07 # 9
gogo46
You have to try and ful the vehicle. I went to 19km of 10tl benzyl, I went 16km, I think it will not be consistent.
08.05.2020 18:07 # 10
herry
I do not know how your financial situation is now but if you want to know how much your car is burning. Complete your vehicle's warehouse once. After driving for 100 km, in the city, you can enter the same station and get a full 100 km. this is the most logical solution. In the meantime, we are in the short month of burning more gas. If you are driving short distances before the vehicle is fully heated, it burns too much. You said "lpg", the friends who wear it should continue to use it, but after this hour, I think getting a new lpg is not so much, there is not much joke. Be careful not to use it more by burning the gas light. respects. Thumbs Up
08.05.2020 18:07 # 11
ahmet_bjk
cold weather does not make such a difference, there must be another problem (if there is no error in the calculation)
Is the location where you fueled different?
Has the vehicle been in maintenance recently?
08.05.2020 18:07 # 12
ahmetismet
it is from hikes Tongue
08.05.2020 18:07 # 13
tongucuk
There is a solution to remove the bulb from the volcano is okay, it will not burn for a lifetime Big smile (I really did it when I had a flash I was overwhelmed by going to a gas station in 2 days recently)
08.05.2020 18:07 # 14
herry
[QUOTE = ahmet_bjk]
There is no error in the calculation, it does not happen with 10tl, this is not the way .. read most of the topic in the forum.
08.05.2020 18:07 # 15
VLKNYKSLN
My brother, use the tank after a full tank. For 1 month, no matter how long it lasts, you should not worry about fuel. I use it for more than 1 month.
08.05.2020 18:07 # 16
GokhaN
2 TL for 10 lira, 4 TL for gasoline.
The cars are burning the worst 10-11 liters in winter, the current data is normal.
08.05.2020 18:07 # 17
tongucuk
You can not understand whether it burns too much by getting less fuel, as everyone says, in cold weather, there is a lot of consumption in durkalk, using fuel at the bottom of the tank by using less fuel, it will damage the engine and the parts.
08.05.2020 18:07 # 18
Can Oksuz
You make the healthiest measurement by finishing the full tank.
If you look at the indicator, the second half of the warehouse goes longer than the first half. Instant consumption is also deceptive.
Other friends have said the other important issue. Try not to drop the indicator below the quarter. Dirt injectors on the fuel can clog in the tank, which means trouble.
08.05.2020 18:07 # 19
vodkaburnblue
I thank you all for your interest and interest.
08.05.2020 18:07 # 20
tongucuk
Thumbs Up
