I'm thinking of buying 307 SW, I have questions for you ??
08.05.2020 16:47 # 1
riptalon
Hi friends. I own the 2000 Model 1.2 Opel Corsa. I also have a slightly crowded family. Therefore, my car has started to seem very small. I have always found SW tools beautiful. I plan to buy a new vehicle in the coming weeks. In my research, I found 307 sw as ideal as price / performance ratio. I think a model with or without makeup with a panoramic glass manual gearbox between 2004-2007. But I have something to consult you; First of all, one of the most important criteria for me is fuel consumption. I do not think of a diesel vehicle, so if I buy from this vehicle, I will use 1.6 gasoline / LPG. What is the fuel consumption of this vehicle according to your experience or knowledge? I am currently burning local LPG ~ 22 cents with Corsa and it will be too much for me. For 307 sw, I saw 10 liters in the city in one place and 8.6 liters in another. My Corsa is burning 8-odd liters of gasoline, but 10 liters is a very cold figure. I ask this for manual gear. It would be nice if the automatic users also tell their data. Also, do these cars have costly chronic problems? I'm not someone who cares about those who say, don't buy it, this expensive brand is not bought. Of course, every vehicle will have some problem. This is valid for every brand. What is the situation with these tools in terms of cost? Thanks to all of you in advance, best regards ...
08.05.2020 16:47 # 2
okan4037
I think I would recommend the beautiful vehicle in all aspects. If only the car like 8 corsa burns 8 odd, why do you feel 10 liters for 307 sw? I think it is normal but you can burn 8 odd, this is a situation related to your driving style.
08.05.2020 16:47 # 3
leony510
don't sw sw
08.05.2020 16:47 # 4
istanbullu_3886
Look, my friend, I have been using SW diesel for 1 year. I am very pleased. My car is 1.6 diesel fuel. It only burns chronical errors until the corset.
08.05.2020 16:47 # 5
istanbullu_3886
[QUOTE = leony510] sw don't take it [/ QUOTE] if you explain what sw said don't take it, let everyone know
08.05.2020 16:47 # 6
riptalon
[QUOTE = okan4037] I think I recommend all kinds of beautiful vehicles .. if the vehicle is burning 8 odd like corsa only, why do you feel 10 liters for 307 sw? I think it is normal but you can burn 8 odd. This is a situation related to your driving style. As a result, I would suggest that after the corsa you will miss 2 upper segments and you will not regret it. The new 1.2s can burn much, much less. 1.2 to 8.5 too, but I use it with lpg. I asked a sw seller how the vehicle burns 22 cents said. He probably lied but it wouldn't be a problem unless he went over 25 (2.30 LPG).
Also, what do you think about the diesel of this model? The reason I don't want to buy diesel is that the vehicles are generally high km and the diesel is more expensive in case of a possible breakdown ...
08.05.2020 16:47 # 7
riptalon
Friends I've seen 2 different consumption so far. It says 9.9 in one and 8.2 liters in one. Which one do you think reflects the truth? Does anyone use this tool? & nbsp; "Smile"
08.05.2020 16:47 # 8
[QUOTE = riptalon] Friends I've seen 2 different consumption so far. It says 9.9 in one and 8.2 liters in one. Which one do you think reflects the truth? no one using this tool? & nbsp; "Smile" [/ QUOTE]
I am a SW user too . 6.7 liters / 100 km in mixed usage. I have a consumer like, but you don't look at my values. These values vary completely according to use. Hence, 9.9 is also logical at 8.2. Reviews
08.05.2020 16:47 # 9
riptalon
[QUOTE = koliva] [QUOTE = riptalon] Friends I've seen 2 different consumption so far. It says 9.9 in one and 8.2 liters in one. Which one do you think reflects the truth? no one using this tool? & nbsp; "Smile" [/ QUOTE]
I am someone trying to use the vehicle very economically. I am not in a hurry, just be less ... How do you keep the average of 6.7 on the roads and speeds?
08.05.2020 16:47 # 10
[QUOTE = riptalon]
I am trying to use the vehicle very economically. I am not in a hurry, just a little bit enough ... How do you keep the average of 6.7 on the roads and speeds?
This is a very flat place and I think it affects the race. On the other hand, you should try not to get up fast on departures. I have nothing else to do "Smile"
08.05.2020 16:47 # 11
metin
I'm trying to drive the car very economically. I am not in a hurry, just a little bit enough ... How do you keep the average of 6.7 on the roads and speeds?
This is a very flat place and I think it affects the race. On the other hand, you should try not to get up fast on departures. I don't have anything else "Smile"
< div> I already admire this fuel consumption of the coach. Consumption of such a 1.6 307 sw deeply hurts me (: & nbsp;
just because of this I even thought about going to belgium & nbsp; "T
08.05.2020 16:47 # 12
[QUOTE = text]
I already admire the coach's fuel consumption. Consumption of such a 1.6 307 sw deeply hurts me (: & nbsp;
Come on text. You have a place in the press "Smile"
08.05.2020 16:47 # 13
fTh206
My proposition of automatic gear burns very much, I have an automatic 206 I do not burn down from 35 to 40 krs per km, I think this ratio will be higher in 307
08.05.2020 16:47 # 14
alilk
In the middle of 2006, I bought 307 sw diesel. Nothing has been released so far. Since these are electronic tools, you should definitely have them serviced at an authorized place. As for his approach, I do not know in TL, I did not calculate at all. But it really holds the factory data. In Diesel & nbsp; on the long road, a tank does not go less than 1300 km. So at 4.6-4.8 L / 100 km. It varies between 6-6.5 liters in the city. As for its performance, it is super for a vehicle of 1435 Kg because of its high torque value. I advise. A complete family car.
08.05.2020 16:47 # 15
rugger35
I bought a 2004 model and I had been dreaming of it for a long time. I love it. pull out and watch the stars, sit on the back seat, settle in the back seat, lay down the middle seat, joke with my son, play my luggage, fill our huge luggage with tons of luggage and trinkets and go on vacation, my boss, 1.6 carries us, while the weather is dark, the rain blows, "boss, let me enjoy! ! " I love the fact that she lights up her headlights, activates her wipers like a swinging girl, smells like a sweet gum, caresses my ears, in short, I love everything ...
Maybe I can give you some idea
08.05.2020 16:47 # 16
orhanax
& nbsp; [QUOTE = alilk] I bought 307 sw diesel in mid 2006. Nothing has been released so far. Since these are electronic tools, you should definitely have them serviced at an authorized place. As for his approach, I do not know in TL, I did not calculate at all. But it really holds the factory data. In Diesel & nbsp; on the long road, a tank does not go less than 1300 km. So at 4.6-4.8 L / 100 km. It varies between 6-6.5 liters in the city. As for its performance, it is super for a vehicle of 1435 Kg because of its high torque value. I advise. It is a complete family car. [/ QUOTE]
What is the secret of this, friend? I have the same car. I can go up to 900 km with a warehouse. Average 6.2 / 100 km & nbsp; "C & nbsp; My car is original. Its engine was not played by its mechanics. Their maintenance is done prematurely. I'm just sitting in a little mountainous place. Does it really matter so much? & Nbsp;
As for the main question; Get it without thinking if my friend found a clean 307 sw. However, if you cope with the problem, there will be no swear words that you didn't give to Peugeot. So check it well before you buy it.
08.05.2020 16:47 # 17
albayman
Let me give you 100km / liter values. Since the 307 sw is 1.5 tons, the LPG consumption in the city can go even higher in extreme situations such as 10 liters and 15 even in continuous sports driving and long-term stop-and-go traffic.
< It may fall below 10 liters in ramped roads and open traffic in very quiet use in the city. but as I said, these values and apply to LPG turkey.
but non-city speaking of things change. On the long way, I know when I burn 8 liters of LPG. straight road with 80km speed.
but with 150 speed on the highway, the trip computer showed 12.5 liters. I have not used it all the time. If you use the vehicle with 100-110 and keep calm, it will not burn 10 liters of lpg.
so, the fuel is absolutely reasonable in calm use with the essence of the word.
If you can afford it, try to buy a make-up case. If it is not enough, take the PACK model in the make-up case because it is the most equipped, and the solutions of its chronic problems are available on this site. there may be things like front layout undercarriage, indoor sounds, airbag failure, air conditioning fan failure, cd changer failure, suspension hardness.
but you will like the glass roof, high equipment, sporty appearance.
5 people and it fits comfortably.
albayman 2013-05-27 23:05:21
08.05.2020 16:47 # 18
ulas81
I bought the 2004 model pack in February, glass ceiling, rain sensor, etc. I have extra cruise control .. as far as I understand, we have the same logic, both wide and beautiful, and less mock :) Once they said the pain is wide and comfortable .. they said that you wouldn't mind approaching peugeot but I did not see any problem yet .. is the thing I care the most. Mine is also from LPG. The air conditioner is always on during the day because of the hot weather .. despite this, the city burns 9 - 9.5 liters of lpg. On the long road, it goes down to 7.5 liters, which is 18 cents or so .. I have many friends around me who are curious about these issues and their comments are very good fuel data for a vehicle with this width, weight and engine volume. I think it is a very handsome tool that can be taken ..
08.05.2020 16:47 # 19
emre_akdag
If you are going to buy 307 sw, you will buy the diesel so that you will enjoy both the fuel and the comfort.
