I'm thinking of buying 106 Quicsilver |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 106 | |
| 08.05.2020 13:58 | # 1 |
haruncoskun |
| 08.05.2020 13:58 | # 2 |
MirakGTI |
welcome to the club If you introduced yourself first If you are familiar, you don't need to show it to the service. KM finds out that it is not original. sales transactions amount from 200 to 500 price came a little cheap for me good forums
| 08.05.2020 13:58 | # 3 |
welcome to us If you have a good master, you don't need to take it to the service. Quiksilvers are not as sensitive as gti. If the engine's chassis is intact, the price is reasonable, because the fairing plate is thin, even a small blow is being distorted. Miles at the moment tells exactly what the service is sales transactions last year 130 lira at notary license change 50 lira insurance was around 140 150 pounds I did all of the processes myself.
| 08.05.2020 13:58 | # 4 |
sinan-s |
If the car is not familiar, you can show it to the master. Notary public does not keep the costs too much. But the quik of 9000 YTL will be nice.
| 08.05.2020 13:58 | # 5 |
Peugeot Services take about 100 ytl. But you can have everything from A to Z. You give money in your money. But 9,000 Ytl is a little thought-provoking, very cheap. They will tell you when they go to service.
| 08.05.2020 13:58 | # 6 |
I mentioned a little bit of myself here :) http://forum.peugeotturkey.com/forum_posts.asp?TID=3228 The price was cheap for me, I have been following qs for about 2-3 months (after the crisis, the decline was obvious). I guess it costs a notary public, I guess it would explode to 10,000 liras if they all made 1000 liras. I do not want to fall into tonga because I have not bought a vehicle before. It is very good to be active about the site, thank you for your interest and interest. |
| 08.05.2020 13:58 | # 7 |
sinan-s |
I would like you to pay attention while buying 106. Don't rush clean. I have been using it for 3 years. Quikiksilver ... We will help
| 08.05.2020 13:58 | # 8 |
The sales link is below. I http://www.sahibinden.com/65000km_2002_model_quicsilver_wqqaxqq11059212wqqpxqqdisplayite Say what? |
| 08.05.2020 13:58 | # 9 |
sinan-s |
[QUOTE = wrew] Sales link below. I http://www.sahibinden.com/65000km_2002_model_quicsilver_wqqaxqq11059212wqqpxqqdisplayite Say what? [/ QUOTE] There is nothing in this vehicle ... Totally flat model ... But you know it. I'm sure if you increase it up to 12-13 billion, you will get more beautiful
| 08.05.2020 13:58 | # 10 |
first check the gaps between the parts in the body of the vehicle (fender, door, door etc.) Is there a layer of paint on the sealing points (windshield, rear window)? Is there any tape mark or paint isolation mark anywhere on the vehicle? check the rear trunk floor for any weld Check the door sheets and the putty on the connection of the fender to the chassis made by hand? or fabricated paste ?? Since the factory paste will harden after many years, it does not migrate into the mollusk harder when nailed. Check the bottom of the vehicle Is there any source or assembly? Are factory presses still intact? Check the wear on the steering and pedals, these are the actual km of the vehicle. will give you clue about. Has the previous owner been meticulous to his vehicle ?? engine cleaning, antifreeze in the glass water, maintenance product in the vehicle's torpedo etc. The saklıyorm? Does it throw dirty smoke from exos? Is there a valve sound? Are there oil sweats or corrosion on the engine block? Start and check the vehicle at a cold moment, especially to test the health of the engine. Especially the door glasses are original? Do the doors open and close easily, are their gaps with the chassis normal?
| 08.05.2020 13:58 | # 11 |
[QUOTE = sinan-s] [QUOTE = wrew] Sales link below. I http://www.sahibinden.com/65000km_2002_model_quicsilver_wqqaxqq11059212wqqpxqqdisplayite Say what? [/ QUOTE] There is nothing in this vehicle ... Totally flat model ... But you know it. I'm sure if you increase it up to 12-13 billion, you will get more beautiful [/ QUOTE] Yes, there is nothing in the car (but its KM is very good), it was cheap and I looked at it because I wanted to do it to my taste whenever I wanted. But as far as I understand, you think the price is suitable for this vehicle. |
| 08.05.2020 13:58 | # 12 |
[QUOTE = hasimayaz] first check the gaps between the parts in the body of the vehicle (fender, door, door etc.) Is there a layer of paint on the sealing points (windshield, rear window)? Is there any tape mark or paint isolation mark anywhere on the vehicle? check the rear trunk floor for any weld Check the door sheets and the putty on the connection of the fender to the chassis made by hand? or fabricated paste ?? Since the factory paste will harden after many years, it does not migrate into the mollusk harder when nailed. Check the bottom of the vehicle Is there any source or assembly? Are factory presses still intact? Check the wear on the steering and pedals, these are the actual km of the vehicle. will give you clue about. Has the previous owner been meticulous to his vehicle ?? engine cleaning, antifreeze in the glass water, maintenance product in the vehicle's torpedo etc. The saklıyorm? Does it throw dirty smoke from exos? Is there a valve sound? Are there oil sweats or corrosion on the engine block? Start and check the vehicle at a cold moment, especially to test the health of the engine. Especially the door glasses are original? Do the doors open and close easily, are their gaps with the chassis normal? [/ QUOTE] Yes, it is a very comprehensive control. There were 80 points and 300 points tests in Car Services. This probably includes the above controls. |
| 08.05.2020 13:58 | # 13 |
Filter out the 2002 model Quiksilvers on Sahibinden.com. Find the average price. |
| 08.05.2020 13:58 | # 14 |
kaiser_soze |
friends have given the necessary information..if you think you have a friend in me 2000 model 75.000km air conditioned 106 quiksilver..as far as I know .. there is no accident etc. .. it wants 11,500 as a price but I guess it can do something ..
| 08.05.2020 13:58 | # 15 |
If the weather is good, I want to participate in this event. I will give you a few links, I would be pleased if you comment on the car, price etc. I http://www.sahibinden.com/temiz_106_2000_modelwqqaxqq10381316wqqpxqqdisplayite I http://www.sahibinden.com/95_000_km_de_2000_model_pejo_106_quicksilver_klimali_ve_sunrofluwqqaxqq11299524wqqpxqqdisplayite I http://www.sahibinden.com/acilll_125_000km_de_2000_model_peugeot_106_wqqaxqq10551963wqqpxqqdisplayite In addition, what problems or disadvantages can be due to the large mileage of the vehicle. Does the engine have Mileage life? thank you |
| 08.05.2020 13:58 | # 16 |
2.If the show is clear, I say buy it If the motor mileage is about 100 thousand, it will not be a problem if it is looked clean. I wouldn't recommend looking at more. The lower the km, the better |
| 08.05.2020 13:58 | # 17 |
Nothing clear from friend pictures ... If you are a serious buyer, you will pick up the phone. You confirm the accuracy of the details about the vehicle, then you go and have it checked by yourself. |
| 08.05.2020 13:58 | # 18 |
My friend is already good, I do not know the prices of the 106s, but I bought 206 2 months ago, the purchase and sale costs went to notary sale 200ytl, traffic insurance 170ytl, 100ytl in vehicle registration procedures, that's all.
| 08.05.2020 13:58 | # 19 |
Hello Friends I still have not received 106 qs. And every day I feel like I'm getting away from it I think this is because the market of 106qs is uncertain. It seems strange to me that the prices between the vehicles with the same features (Model and KM are not modified close) are 2-3 thousand liras, or everyone is full seller ![]() In the meantime, I follow the ads from sahibinden.com. Only the prices of the really urgent ads seem realistic to me. It does not stop at such advertisements, it is sold. ![]() Have a nice holiday. |
| 08.05.2020 13:58 | # 20 |
Hello again, should I take it to the Authorized service or Private service when buying a vehicle? I talked to Mepa Automotive (Authorized Service) in hunters, they reported a fee of 50 TL + VAT for their electronic and mechanical tests. Will these tests be sufficient? Is there anything else I should do? Thanks for the help! |
