I'm pressing the 206 gas, it is running out
08.05.2020 20:14 # 1
ziya alp
friends 2 3 4 5 presses to gas more than 2 cm pressure is pressed to the back of the pad lining the car 1 2 the car is clicking, the button is running, the clutch presses the cut off, my advance valve is broken, thank you from now broken car 2005 1.4 petrol / lpg
08.05.2020 20:14 # 2
ziya alp
Did anyone know why 28 people read the reason for Allah's sake?
08.05.2020 20:14 # 3
lazerburak
If the click sounds, the clutch stops cutting, the problem is probably from the gearbox.
08.05.2020 20:14 # 4
onlycihan
I do not know much about this, but when there is an idle, there is a sound coming, when the pressure on the clutch goes, sometimes it starts again and sometimes it does not do it. The incontinence that I understand is usually caused by other lining problems. This is much more understandable if you shoot and share a video
08.05.2020 20:14 # 5
If he is making evasion, the pressure is in the pad. When I say click, it does not accumulate, if there is no vehicle, press the gas and pop it.
08.05.2020 20:14 # 6
Bahri
[QUOTE = onlycihan] I don't know much about this, but there is a voice coming in when idling, when the clutch presses the sound, sometimes it starts again when it stops, sometimes it does not. The incontinence that I understand is usually caused by other lining problems. This is much more understandable if you shoot a video and share it [/ QUOTE] that sound is likely to come from the clutch bearing.
08.05.2020 20:14 # 7
dejawu1978
that sound is most likely coming from the clutch bearing. The print lining seems to change the clutch bearing
Thumbs Up you made a nice point shot if the clutch is cut to pressure, it will be from the bearings, if it makes sound without pressing the opposite, it will be from the gearbox
08.05.2020 20:14 # 8
ziya alp
It goes out like a diesel car.
08.05.2020 20:14 # 9
The pressure is coming from the clutch bearing as our friends say. I think you will have to change it all at once. you don't give any more workmanship.
