I'm new, can you help me?
08.05.2020 21:10 # 1
Yasin_Tr
Hello friends, I bought a Peugeot for the first time and I have a few problems. Can you help me with these? Vehicle 206 1.4 hdi x design 2005 model 197 thousand, I have 2 problems. As it passes through the 1st hole or something, the back sounds like blunt as if there was no suspension. When the 2nd vehicle is in gear, when you press the gas, a sound like a ball sound comes from the front. On the other hand, the temperature goes up and down a click of 90. I use Peugeot for the first time, I don't know what the hell :) There are normal springs on the vehicle and I want to replace them with sports springs. What are your recommendations?
08.05.2020 21:10 # 2
GokhaN
Hi
Use your vehicle without accident
1. It's time to fix the torsion of the problem
2. Look at the motor ears in the problem
Around 90 degrees of heat
08.05.2020 21:10 # 3
ersin61
In addition to the second problem, look at the crank pulley ...
08.05.2020 21:10 # 4
maximusti
In addition, make sure that the 1st stage fan is working,
Many masters call this heat normal and shake it, but when the temperature of the vehicle hits 100, it turns on the 2nd stage fan.
