I'm looking for answers to what I don't know about the vehicle :)
08.05.2020 16:12 # 1
loiz
Greetings, I'm a stranger to pug, I'm starting to learn slowly. But there are a few things I couldn't solve. I'm waiting for your help ..
1. What is the location of the car's jack? should be..da where ???
2. The maintenance of the vehicle is done in my relative's mobile lubrication washing station.
3.bi how many days for the first time the car starts to make a sound in the idle until it gets warm at the first start, it cuts the gas when it is touched, it repeats when it returns to idle and disappears when it gets hot, it started to make a sound like this. I realized what I did when I made it right or left. Why? Seriously? Is there a way to cut the sound?
I want what is the most proper shape, your advice? back torsion, what kind of bow should I take forward? Should I change the shock absorber? Is torsion troubles? the vehicle is 115 thousand.
For now I am waiting for your help with your information sharing.
08.05.2020 16:12 # 2
Reviews 1. I remember that it is getting inside the spare wheel.
2. Press and hold the button on the odometer before rotating the vehicle's contra. On the other hand, turn the contact over. The countdown will start from 10 on the display. When it is zero, the service counter is reset.
08.05.2020 16:12 # 3
loiz
[QUOTE = Koliva] Member 1. I remember that it is getting inside the spare wheel.
2. Press and hold the button on the odometer before rotating the vehicle's contra. On the other hand, turn the contact over. The countdown will start from 10 on the display. When the zero is zero, the service counter has been reset.
I have never dismantled the spare wheel since I bought the spare wheel. to see if it fits.
I immediately get down to the parking lot for the service counter, thanks koliva.
08.05.2020 16:12 # 4
For the jack, you can enter the servicebox and look at the diagram. If you say I can't, I can handle it if you give the chassis number.
08.05.2020 16:12 # 5
loiz
teacher, I went down to the park, I reset the service counter, thank you, I do not know the chassis number right now, the license is not with me.
08.05.2020 16:12 # 6
loiz
I have questions, can I get answers without opening a new title, I wonder? >
Can I get the 2nd spring recommendation? Which is good? The price is suitable?
2 cables come out of the brake pedal of the 4th brake pedal, more precisely 2 cables come out of the brake gas clutch.
08.05.2020 16:12 # 7
loiz
no idea advice yaw :(
08.05.2020 16:12 # 8
feline
Let me answer the first question, the nurse first searched the site, the topic has passed
2.I have no relation to the problem with the springs :))) It would be precise to be a model.
4.cc definitely wouldn't be wasted. I had 4 cables.
08.05.2020 16:12 # 9
alisuat
1) You can do it with a pioneer tape and a necessary apparatus, but the screen goes back. >
3) yes arm and com 2000 le, you also need 3 lines of screen. but com 2000 had you made it, explained it with pictures
4) You can activate it with the cruise control arm.
08.05.2020 16:12 # 10
loiz
4.gas is not wire-wired in the room, but 2 cables are coming out of the brake .. they pull the cable to the ecu, but this time I heard that the ecu cannot activate the cc too .. I asked for clarity ..
3.3 lines display And when I do com2000, this car is writing all of its fuel values, so now I mean, I did not buy com2000, I did not go to my logic, as if there was a key in there, it is not closed with nails, it can not be so simple, but I will do this. . & nbsp;
The reason I researched the subject of the 1st tapes is that the screeners go to the screen. What else will I find ..
2. I'm traveling like a stork, how much should I get from which bow? : D & nbsp;
by the way, don't mix the numbers & nbsp;
08.05.2020 16:12 # 11
4) My suggestion is to attach Eibach 3.5cm to the front and lower the back torsion by 1 tooth. You don't have to change the shock absorber.
But if you want to get even lower, you can get Eibach 5cm. But this time you may need to change the shock absorber. Also, the comfort decreases very much, the front gear is easily worn.
08.05.2020 16:12 # 12
loiz
[QUOTE = Berkay] 4) My suggestion is to attach Eibach 3.5cm to the front and lower the back torsion by 1 tooth. You don't have to change the shock absorber.
But if you want to get even lower, you can get Eibach 5cm. But this time you may need to change the shock absorber. Also, the comfort decreases very much, the front team is easily worn.
I had 3.5 + 1 teeth in my mind. thanks ..
They say that torsion can be troubled. As a result, it has not been touched for 7 years.
08.05.2020 16:12 # 13
alisuat
Whatever you do, it doesn't write a song playing on the screen, but if you buy a tape that suits the interior lights, I think it is more charismatic anyway. screen top trip computer screen.
08.05.2020 16:12 # 14
loiz
[QUOTE = alisuat] no matter what you do, it doesn't write a song playing on the screen, but if you get a tape suitable for the internal lights, I think it is more charismatic, I bought a 307 pioneer tape with a red-colored usb-input tape, and when I plugged it, I was wearing an orange-backed usb, bottom air conditioner screen in the middle tape screen top trip computer screen.
However, I do not have a trip computer at the moment, so I do not want to plug in the tape and cancel the screen. I know it will happen.
08.05.2020 16:12 # 15
alisuat
it wasn't mine, but there were those who got it active. It was between 30 TL and 100 TL.
08.05.2020 16:12 # 16
loiz
After there is no control and screen, I will either make the aux input or orj. cd player tape finder ... otherwise I do not tape ..
thanks
08.05.2020 16:12 # 17
alisuat
There is nothing to do at 206. If it is 307, CD changera is inserted, the screen with sd card input is used, then.
08.05.2020 16:12 # 18
loiz
It was good, not at least the sound system, but at least we got rid of that radio addiction.
