I'm looking for answers to a few questions Support please.
08.05.2020 18:23 # 1
serkomser
I just joined you, I switched from Honda to Peugeota. I want to have information about the vehicle. I want to know the pros and cons in my car. These will be with your help. I have listed what I want to ask below. I would be glad if friends with knowledge about the subject answer.
1) Where is the Oil Indicator light indicated in the 307s? I see that there is a sign of oiler when the sun shines on the indicator in my car, but the light should blink when I turn on the ignition but it doesn't light up, could it be defective?
2) When I give light gas while in 2nd gear while traveling and pull my feet out of the gas, it seems like the car is shaking back and forth.
3) I measured the vehicle's fuel values too much according to factory data, how can I do the measurement and what are your values? My data is 12LT / 100KM I press the gas but 100 / 110km / h
4) Reading (where the watch) panel is faint when it gets hot Is there a clear and rational solution to this?
5) What are the dial buttons on the display (0s on the right) on the left?
6) How did the music columns on the front console work?
Thank you.
Eurest 2014-04-11 09:40:50
08.05.2020 18:23 # 2
ahmet_bjk
firstly welcome to us
I am using 308 so I will try to answer your questions according to 308 as many things are the same as 307.
1) When you turn the ignition one turn, you will see OİL OK. In this case, there is no problem in your oil. The oiler sign illuminates when there is a problem with the oil of the vehicle. If it is not on, it means no problem.
3) You did not write the model of your vehicle and whether it is gasoline or diesel, but if you look at your fuel data, it seems that it is gasoline. It is difficult to capture factory data. The healthiest measurement is to fill the tank and travel for 100 km and reload. If you cannot do this, reset the km when the fuel light is on and take some fuel (the more you measure, the more precise you can measure) again.
4) The solution is to change the screen.
5) Adjusts the light color or intensity of the instrument panel.
6) There may be a distortion in the settings of the sound coming from the right or left on the player, if there is no such situation and there is no sound from both sides, there is a problem with the connections or speakers.
08.05.2020 18:23 # 3
serkomser
Thank you,
Click for answers
Yes, my car is gasoline, I already see the text OIL OK. There is no problem in this. ABS, Airbag, Battery etc. lights are turned on when I turn the ignition 1 turn, they turn off when I turn 2 laps.
08.05.2020 18:23 # 4
cavit cevo
2 question answers I have to change the engine chocks
08.05.2020 18:23 # 5
ahmet_bjk
[QUOTE = eurest] Thank you,
Click for answers
I guess those lights show that it's checked and if there is no problem, it goes out when the vehicle starts. It may not be lit because OIL OK shows the control of the oil. If the vehicle lights up while running, there is a problem, in this case there is no problem.
08.05.2020 18:23 # 6
serkomser
[QUOTE = cavit cevo] 2 question answers I have to change the engine chocks
[/ QUOTE] When I open the hood, there is a big engine connector (Ear) on the left just before changing it. Should I replace the others, or are the motor ears and the chocks different things?
08.05.2020 18:23 # 7
pusutr
Hello there. As the cvbo of 2 problems, I think the event you mentioned is doing when the engine is cold. Doesn't go through when it gets hot? I know this is normal.
08.05.2020 18:23 # 8
serkomser
[QUOTE = pusut] Hi. As the cvbo of 2 problems, I think the event you mentioned is doing when the engine is cold. Doesn't go through when it gets hot? I know this is normal.
[/ QUOTE] pusutr;
It does not matter whether it is hot or cold, it is doing as I said on the road, when I press 3-5 cm gas and pull my foot again, the car shakes back when I press forward. There is no knock on the gears, but I can feel the gears, even gears are felt. I never thought it was from the engine or transmission ears, but the situation shows that. I'll have it checked and share the situation with you.
08.05.2020 18:23 # 9
kuscu38
May your vehicle be good, there may be problems with the column connections.
If your chocks do not have any problems, as your friend said, there may be a problem with one of the coils or a small possibility from the press pad.
kuscu38 2014-03-20 10:45:27
08.05.2020 18:23 # 10
kuscu38
Have a look at your oil sensor. If it does not appear on the first turn of the ignition, it may be from the oil sensor.
08.05.2020 18:23 # 11
serkomser
[QUOTE = kuscu38] good luck, there may be problems with column connections.
[/ QUOTE] Thank you, thank you.
In the first days I started driving, it was kicking, spark plugs changed (Bosch) misfire started to decrease over time, couldn't be sure whether there was a coil failure or not, and the problem would increase, the problem would increase, then we could understand it easier. Even though it is very rare now, the car is like if I am kicking or not. How else can we tell if the coil is faulty?
As I said, I will write you the answer that I will look at the chocks today.
08.05.2020 18:23 # 12
kuscu38
The coils are expensive, even if you have the opportunity to go to the output of 85 lira or even that of the tofaş, if the vehicle is doing where it stops, unbalanced operation without moving etc. When you go to the stabler like you try there, you get a recovery. If you say no doing it on the move, it does not eat gas, it makes a popping sound when starting the car.
08.05.2020 18:23 # 13
rzsrht
[QUOTE = eurest] [QUOTE = cavit cevo] 2 question answers I will also have engine chocks
[/ QUOTE] When I open the hood, there is a big engine connector (Ear) on the left just before changing it. Should I replace the others, or are the motor ears and the chocks different things? [/ QUOTE]
teacher, how much have you changed your ear? sometimes I feel the engine shaking even in light pits.
08.05.2020 18:23 # 14
serkomser
I changed this piece to 110.00TL. While performing heavy maintenance with a timing change in a private service ...
Eurest 2014-03-20 14:08:04
