I'm looking for a solution to 307 faults
08.05.2020 18:41 # 1
simirnoffredbull
I wish everyone good Ramadan. I try to consider the failure in my car by occasionally, but I still have not reached the solution.
My problem is this: It usually happens when the car's engine gets warm after starting off with my vehicle , the idle drops below 1000 rpm when I shift the gear down and gives the pressure oill too low error at the same time, the stop flashes but the vehicle does not stop, the idle rises with a slight flickering. or something else. The filters were originally removed and reinstalled. I would like help with this.
I think I can do it because the oil in the engine is thinner, but I do not know why it is so I am thinking of putting a degree of thicker oil in the first maintenance. Thanks in advance
08.05.2020 18:41 # 2
ahmed206
Excerpt from another forum:
"The friend went to take the vehicle out of service right now :) They said the problem was solved.It happened because they used the oil filter. :)
They said that there was an old oil deposit in the sump in the case of oil dripping, it was dripping, we will look at it. "
08.05.2020 18:41 # 3
simirnoffredbull
There is no forum left on the internet, my friend. Thanks for your help.
08.05.2020 18:41 # 4
tongucuk
I think your problem may be related to the oil pump. If you do not know it wrong, it must be an oil pressure error. If you search for a solution in this direction, you can reach the solution more easily.
08.05.2020 18:41 # 5
What is your car engine? Is the gasoline 1.6 horse or Diesel 1.4 HDI? Diesel or Diesel? How many horses and power of the engine do you type? When the stop sign shows, don't go too far, stop where you are and take it to your service.
peugeot 307 1.4 HDI 2014-07-08 22:29:37
08.05.2020 18:41 # 6
yolsever
Friends, the same fault happened to me the day before Christmas: my car came to 5000 cycles idle and I got this warning, my car was working, but I called the master, if your car is running, you should bring it to the shop, I was slowly bringing the engine 500 meters before the shop, and it was locked, I had to change the engine completely because it was scraped. .
When this fault alert comes:
- never start and run your vehicle
As for the reason
1-oil may have lost its property.
2-oil filter sub-industry may be installed (definitely use original)
3- Worst of all, as I have, the oil pump may be broken.
08.05.2020 18:41 # 7
albayman
oil pressure low warning.
If the oil pressure is normal, the sensor may have malfunctioned, if it can be changed without turning on the engine, it is better to replace it first.
if the problem is not in sight, it may possibly be from the pump.
If the pressure is really low, not enough oil is pumped into the friction parts, wear increases.
08.05.2020 18:41 # 8
peugeot murat
your car 1.4 92 hp gasoline et3 engine in these engines i had a few of these problems due to the wear of the main bearings due to low oil pressure in the relay due to boron power try the engine will hurt
